Port number now showing up in address
Postby mockingbrd » Mon Jan 21, 2013 4:54 pm
I just performed a fresh re-install of subsonic. I used the automatic port forwarding option in the subsonic settings previously and now again after the re-install. Previously, all I would have to do is type in my IP address to get to my subsonic login. Now, the port is required at the end of the IP address (see below).
Before: XX.XXX.XX.XX
Now: XX.XXX.XX.XX:4040
My problem is that the majority of my users have JUST the IP address in their clients (my subsonic.org registered address goes down sometimes). I'd like to get my settings back to JUST requiring the IP address as opposed to needing the port number at the end as well.
Help? Thanks.
Screen shot of my network settings below:
mockingbrd
Re: Port number now showing up in address
Postby bushman4 » Mon Jan 21, 2013 6:25 pm
Change your ports to port 80 for http traffic and 443 for ssl traffic (if you use that).
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby mockingbrd » Tue Jan 22, 2013 1:46 pm
bushman4 wrote:Change your ports to port 80 for http traffic and 443 for ssl traffic (if you use that).
Worked. Thanks Glenn!
mockingbrd
