Where is the playlist data stored? Can't restore playlist.
Postby visserj » Sun Jan 27, 2013 12:24 am
Hi - I've been working on this for a few hours - trying different ways to restore data following an upgrade from 4.7 beta 3 to 4.7.
Eventually I've given up and have now restored most of my data by manually running by backed-up subsonic.script through the http://<subsonic>/db.view utility.
My playlists are now showing up in Subsonic - but they have no files - clicking on them gives a "playlist empty" result.
Does anyone know where the actual file list data is stored - I can't see it anywhere in the database.
Or maybe you have some tips about how to restore user data when going from 4.7 beta to 4.7 (I've tried copying db/ folder and the subsonic.properties files - but I get 503 error and "MEDIA_FILE" java error). But I'm nearly there using this manual approach now - just the actual playlist data to go...
thanks
Jon
visserj
Re: Where is the playlist data stored? Can't restore playlis
Postby BKKKPewsey » Sun Jan 27, 2013 12:56 am
As far I can see the actual media files are listed in playlist_file table.
But the media files are listed by media file ID - so not too helpful :(
Postby visserj » Sun Jan 27, 2013 1:26 am
I see - thanks for the tip...
But I can't find any INSERT statements for that table in my backup script - any idea how this table is supposed to get filled during a normal upgrade?
visserj
Postby jsonnabend » Mon Jan 28, 2013 7:17 pm
I use "update media_file set present=true where present=false". That seems to fix the empty playlist bug. I run it every night using cURL in a batch file.
- Jeff
jsonnabend
