need help trying to get folders from another computer
Postby rlk123go » Mon Feb 04, 2013 3:50 am
need help trying to get folders from another computer on my network! IVE READ THE WALKTHROUGHS POSTED ON THIS FORUM BUT GET LOST AFTER I GET INTO SERVICES\SUBSONIC PART PLEASE HELP AS IM NEW TO THIS PROGRAM APP LOVE THE APP SO FAR! :( :o
rlk123go
Re: need help trying to get folders from another computer
Postby BKKKPewsey » Mon Feb 04, 2013 12:54 pm
And you are running SS on? :?
Postby rlk123go » Mon Feb 04, 2013 4:42 pm
oh my bad im using windows 8 main system, trying to get music files from windows 7 machine!
rlk123go
Postby BKKKPewsey » Mon Feb 04, 2013 10:11 pm
Are the folders on the win 7 pc setup for shared?
E.g. Can you access them from the network without supplying extra password info?
If so then:-
Ok I am am going to assume that Win 8 is similar enough to vista/Win7 for this to work.
  1. You need to run services.msc (How on Win 8 no idea)
  2. Scroll down the list until you find the subsonic service
  3. Right click on it and select properties
  4. Change to the log-in tab
  5. Change the radio box from system a/c to "this a/c"
  6. Hit the browse button
  7. In the new window type your user name and select check names
  8. Hopefully your user name will then appear so select it
  9. Hit OK to get back to previous window then enter your password in the boxes below.
  10. Hit ok & close program
  11. Now reboot pc
SS now should have the privileges to access the network folders
A better method is to setup a special user a/c (non-admin) especially for SS
Use that information portal known as google for further info on how to that.
Postby rlk123go » Wed Feb 06, 2013 3:02 pm
ok I got it into the higher elevation! but now it wont run in the subsonic control panel, in the service status it says (not running. auto-start). Im sorry for being clueless but this is the first time using this app thanks for helping me with this. I like this app its cool!
rlk123go
Postby BKKKPewsey » Wed Feb 06, 2013 8:36 pm
And the control panel is red?
Assuming that you did reboot the pc go back to services.msc - highlight subsonic and you should get an option to start the service.
Start it and it should (after a while but no longer then a minute) show as running.
If that doesn't work you may have to wait for someone who is running Win 8 to help
Postby rlk123go » Thu Feb 07, 2013 1:08 am
no Its not Red. It Just says (not Running. Auto start) & Server address is blank on the status Tab! Settings Tab port number IS what the tutorial Recommends. I had Subsonic working with my Local account .
rlk123go
