Error
Error
Postby whatwasthat4 » Sun Feb 17, 2013 9:38 pm
I'm on Windows 8, and finding that 4.7 does not recognize new MP3 files when added to my folders, so I downgraded to 4.6. I recevied the below error, anyone know what it means?
java.lang.OutOfMemoryError: Java heap space
at java.lang.Throwable.getStackTraceElement(Native Method)
at java.lang.Throwable.getOurStackTrace(Throwable.java:826)
at java.lang.Throwable.getStackTrace(Throwable.java:815)
at org.apache.jasper.servlet.JspServletWrapper.handleJspException(JspServletWrapper.java:440)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:375)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:362)
at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:268)
at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:126)
at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:236)
at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:257)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1183)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:902)
whatwasthat4
Re: Error
Postby BKKKPewsey » Sun Feb 17, 2013 10:54 pm
whatwasthat4 wrote:I'm on Windows 8, and finding that 4.7 does not recognize new MP3 files when added to my folders, so I downgraded to 4.6. I recevied the below error, anyone know what it means?
Bit of a clue there :?
Increase the memory allocation via the control panel - 250MB should be OK.
Re: Error
Postby whatwasthat4 » Mon Feb 18, 2013 12:34 am
Thanks that got me going again! Any idea why 4.7 doesn't seem to pick up new files? I'd like to move to the current version, but this is holding me back. :|
whatwasthat4
Re: Error
Postby bushman4 » Mon Feb 18, 2013 3:53 pm
Are you rescanning when you add new files?
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Re: Error
Postby whatwasthat4 » Tue Feb 19, 2013 12:21 am
Yes, but it does not recognize the new files. Same goes for any files I move. If I run 4.6, it picks them up. 4.7 does not though. :?
whatwasthat4
Re: Error
Postby whatwasthat4 » Tue Feb 19, 2013 12:31 am
Tell me this isn't crazy... I can uninstall the program, reinstall it, and it keeps all my settings/media folders. If I could find where the index is, I'm sure that would fix it. Well... I'm not SURE. But I'm willing to try it. :D
whatwasthat4
Re: Error
Postby BKKKPewsey » Tue Feb 19, 2013 3:16 am
If you want to do a clean install just delete the c:\subsonic folder 1st.
That will delete ALL your settings so have your license info to hand.
Re: Error
Postby whatwasthat4 » Tue Feb 19, 2013 11:23 pm
whatwasthat4
