Network error on android app ????
Postby Geko » Sat Feb 23, 2013 4:20 pm
Hi there
I managed to setup my server and do all the port forwarding
it says on the mainscreen control panel the following
Status: Successfully forwarding port 4040.
Status: xxxxxxxxxxx.subsonic.org responded successfully.
therefore all is well
I downloaded the app for android and added my server address
it says (contacting server )
then says network error
Please help !!
Geko
Re: Network error on android app ????
Postby GJ51 » Sat Feb 23, 2013 6:21 pm
Does your phone connect to the Subsonic demo server?
Postby Geko » Sat Feb 23, 2013 6:45 pm
yes the demo server works
I have also a paid liscence.
Geko
Postby alphawave7 » Sat Feb 23, 2013 7:20 pm
Does canyouseeme.org test pass your port 4040?
Postby Geko » Sat Feb 23, 2013 9:29 pm
it says Error: I could not see your service on 86.128.56.247 on port (4040)
Reason: Connection timed out
I have a static ip . I port forwarded correctly
I don't get it
Geko
Postby alphawave7 » Sat Feb 23, 2013 10:03 pm
Geko wrote:it says Error: I could not see your service on 86.128.56.247 on port (4040)
I don't get it
Try a router reboot, and also ensure SS is running.
Postby Geko » Sat Feb 23, 2013 10:23 pm
I switched eset nod 32 onto interactive mode and now it works :) :)
thanks alot guys
Geko
Postby Geko » Thu Feb 28, 2013 3:41 pm
new problem guys !!!
right before i explain my problem
I am a paid user . i have the latest version of subsonic installed
my pc : windows 8 64bit
itel core i5-3210M 2.5 Ghz
memory 8GB
nothing is overclocked or the likes
i have java 7
My router is a BT homehub 3
I have forwarded ports 4040 to my computer on the router using tcp protocal as explained in the tutorial
when i check canyouseeme.org it shows success and the port is open
i have a static ip set
on the browser control panel for subsonic it shows
Status : Successfully forwarding port 4040
Status myname.subsonic.org responded successfully
Everything looks great right ?
its not even close !
I installed the subsonic app on my phone
i tested the demo server , everything worked well i could play songs etc
when i test my server over the wireless network (using wireless internet on phone) in subsonic it say "network error"
it atempts 4 times but to no avail
i added the exception of subsonic to eset smart security 5 firewall and even added a new zone to allow complete traffic and access
to and from subsonic . so the firewall is not the issue
if i use data connection (mobile network ) instead of wireless on my phone then it connects straight away to the server without a glitch
I am deeply confused by this ??
please help me oh wise ones
dont come with any port forwarding nonsense as i am adept at this
Geko
Postby GJ51 » Thu Feb 28, 2013 4:11 pm
Have you tried using the internal_IP:port_# address in the phone app?
e.g. 192.168.0.2:4040
Of course, use your internal server ip and port number.
What happens?
The only likely explanation is that your router is either not set up for, or is incapable of doing loopback address resolution.
