Service Not Starting With Windows 7
Postby Nikonerik » Sat Feb 23, 2013 8:16 pm
After a clean install of Windows 7 and SS/MC . . .
Subsonic service does not start when Windows starts.
Startup Folder contains a shortcut that points to subsonic-agent.exe
In Services control panel: Subsonic is set to Automatic
Please advise.
Nikonerik
Re: Service Not Starting With Windows 7
Postby Nikonerik » Mon Feb 25, 2013 1:49 am
Really?
No suggestions??
Nikonerik
Postby bushman4 » Mon Feb 25, 2013 2:34 pm
What does the event viewer say?
Does it start if you manually start it?
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby Nikonerik » Mon Feb 25, 2013 3:45 pm
Now that you mention it, I haven't looked at the event viewer. I will tonight. It only seems to work if I click on Start>Subsonic>System Tray Icon.
Nikonerik
Postby Nikonerik » Wed Feb 27, 2013 2:59 am
Here's what I could find in the event viewer:
Cab Id: 0
Problem signature:
P1: subsonic-agent.exe
P2: 0.0.0.0
P3: subsonic-agent.exe
P4: unknown
P5: unknown
P6: 200
P7: -1
P8:
P9:
P10:
C:\Users\. . . .\AppData\Local\Temp\{e87735f3-4892-4f40-bec6-b758cba04fed}\appcompat.txt
C:\Users\. . . .\AppData\Local\Temp\TabC2D1.tmp
These files may be available here:
C:\Users\. . . .\AppData\Local\Microsoft\Windows\WER\ReportArchive\NonCritical_subsonic-agent.e_ed19e387dd9df3c1d216a4e7a5f80b659de14b_13f2ce36
Analysis symbol:
Rechecking for solution: 0
Report Id: 3af4fdc7-7b06-11e2-8521-c8600073291c
Report Status: 0
Service Control Manager:
The Subsonic service is marked as an interactive service. However, the system is configured to not allow interactive services. This service may not function properly.
Nikonerik
Postby GJ51 » Wed Feb 27, 2013 4:57 am
I haven't used the standard Windows install for some time now, but isn't there a setting somewhere on the services panel that allow you to check a box that says something about allowing the service to interact with the desktop?
Just a hunch ...
http://technet.microsoft.com/en-us/libr ... 39(v=ws.10).aspx
Postby Nikonerik » Wed Feb 27, 2013 5:25 am
Yes, I looked into that. It was checked all along.
Nikonerik
Postby GJ51 » Wed Feb 27, 2013 5:58 am
Then the most likely explabation is that the registry entry isn't configured properly to allow the service to interact. The easiest fix is probably to just do a clean reinstall.
I'd uninstall all Java instances and Subsonic through Conrol panel/Programs and Setting, delete the C:\Subsonic directory if you don't have a lot of history yet, and then reinstall the latest Java and Subsonic.
If you already have a lot of users and history, you can try it without deleting C:\Subsonic, or making a backup to try and restore later.
Postby Nikonerik » Wed Feb 27, 2013 11:10 am
I have already performed a reinstall. Problem persists.
I'd like to try and repair the registry settings.
This new behavior with Subsonic follows a fresh install of Windows 7 on a SSD drive. So the OS is clean and updated. Java is current too.
(sigh)
Nikonerik
Postby BKKKPewsey » Wed Feb 27, 2013 1:39 pm
Have a look in the registry HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Subsonic
The Start parameter should have a value (Dword) of 2.
Also check any other ControlSets you may have.
Postby Nikonerik » Sat Mar 02, 2013 1:23 am
BKKKPewsey wrote:Have a look in the registry HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Subsonic
I don't know what you mean by check any other ControlSets . . .
Nikonerik
Postby BKKKPewsey » Sat Mar 02, 2013 3:39 am
Nikonerik wrote:I don't know what you mean by check any other ControlSets . . .
http://support.microsoft.com/kb/100010
