Can't Force HTTPS to 8080? (It jumps to 8433)
Postby Fashdey » Tue Mar 05, 2013 9:03 am
Hey Guys! :D
(I did search for my problem but couldn't find a solution that answers my question)
SUBSONIC_ARGS="--port=4041 --https-port=4040 --max-memory=150" (Works as it should)
I have this problem, I'm setting up my server for HTTPS 4040 and HTTP 4041 which works fine, but when I'm at school those are blocked,
which 8080 isn't.
Then I wanted to change to 8080 so I can connect from more public places
But when I set SUBSONIC_ARGS="--port=4040 --https-port=8080 --max-memory=150"
and connects to the 8080 using https:// it changes to 8433 ?
Simulation
https://xxx.xxx.xxx.xxx:8080 when I go to this it changes to
https://xxx.xxx.xxx.xxx:8443/login.view?
Which I can't view from school/public places.
I just HTTPS to stay at 8080 (Is that possible)?
I will try and see if I can get a log for the HTTPS 8080/8443 but atm. I can't see the page (either from my phone which is my currently most open connection)
Any Sugestions/Need of more info?
INFOs
Linux: Ubuntu Server Ed. 12.10
Services That could interfeer: Apache (80/443)
Server-Router: NONE/NO Firewall (Hosted at a Datacentre)
SubSonic Version: 4.7 (build 3105) – September 11, 2012
Server: jetty-6.1.x, java 1.6.0_27, Linux (60.7 MB / 90.4 MB)
Log (Using http 4041 https 4040)
[3/5/13 9:06:31 AM CET]   INFO   DaoHelper   Checking database schema.
[3/5/13 9:06:33 AM CET]   INFO   DaoHelper   Done checking database schema.
[3/5/13 9:06:34 AM CET]   INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Wed Mar 06 03:00:00 CET 2013
[3/5/13 9:06:35 AM CET]   INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue Mar 05 09:11:35 CET 2013
[3/5/13 9:06:38 AM CET]   WARN   NetworkService   Failed to find UPnP router using WeUPnP library.
[3/5/13 9:06:38 AM CET]   WARN   NetworkService   No UPnP router found.
[3/5/13 9:11:35 AM CET]   INFO   PodcastService   Starting scheduled Podcast refresh.
[3/5/13 9:11:35 AM CET]   INFO   PodcastService   Completed scheduled Podcast refresh.
[3/5/13 9:38:28 AM CET]   INFO   VersionService   Resolved local Subsonic version to: 4.7
[3/5/13 9:38:29 AM CET]   INFO   VersionService   Resolved latest Subsonic final version to: 4.7
[3/5/13 9:38:29 AM CET]   INFO   VersionService   Resolved latest Subsonic beta version to: 4.7.beta3
[3/5/13 9:43:03 AM CET]   INFO   PlayQueueInputStream   Fashdey listening to "c-lakeDOTcom/Crystal Lake feat. K&K - All I Want 4 X-Mass.mp3"
Fashdey
Re: Can't Force HTTPS to 8080? (It jumps to 8433)
Postby Fashdey » Tue Mar 05, 2013 1:53 pm
I've read up some stuff like the restrictions of <1024 (low ports) is for root only and stuff like that
And 8080 is also a restricted port, but how do I make a workaround that you guys think would work? :)
I really hope someone wants to help me, because I can't really use the software as intended without port 8080 :(
Fashdey
Postby wezman2k » Mon May 06, 2013 7:59 am
I've been playing with this for a good while as well and I still haven't been able to figure it out. Any luck?
wezman2k
Postby sindre_mehus » Mon May 13, 2013 1:55 pm
I was able to reproduce this bug, but I haven't found a fix for it.
I believe the 8080 -> 8443 redirect is done automatically by Jetty. It seems only to happen when setting https port to 8080. Other ports I tried worked fine.
