Subsonic in the UK/England
Postby somercamb » Sun Mar 10, 2013 4:06 pm
Does Subsonic work in the UK/England? I gave my personal site name to a friend but they cannot access it. They just get the subsonic homepage. I did look on the board (viewtopic.php?f=2&t=121&p=382&hilit=england#p382), but found no answer to this.
And my friend is using Safari
Thank you
somercamb
Re: Subsonic in the UK/England
Postby BKKKPewsey » Sun Mar 10, 2013 5:10 pm
somercamb wrote:Does Subsonic work in the UK/England?
Yes
Postby somercamb » Sun Mar 10, 2013 5:32 pm
i figured as much.
Two questions:
Why would my friend be seeing only the home page of subsonic and not a login page for my personal subsonic site?
Does Safari have anything to do with it?
somercamb
Postby alphawave7 » Sun Mar 10, 2013 6:25 pm
somercamb wrote:i figured as much.
Two questions:
If your site is available on the WAN (verified?) and responds properly to your subsonic.org address, perhaps he mistyped?
Postby somercamb » Sun Mar 10, 2013 8:17 pm
I'm in the US and he is in the UK. I sent him the site name. Would you like me to PM you the address to see if it works for you? How do i know if it is WAN verified? Not even sure what that means. thank you
somercamb
Postby BKKKPewsey » Sun Mar 10, 2013 8:56 pm
You cam send me the link, by pm, if you like, as that would be a proper test.
alphawave7 wrote:If your site is available on the WAN (verified?) and responds properly to your subsonic.org address
Do your settings/network show that your Yourname.subsonic.org address is successfully registered
Postby BKKKPewsey » Mon Mar 11, 2013 2:26 am
There must something odd with your friends browser, pc or typing, cause I can access your site np :?
Postby somercamb » Mon Mar 11, 2013 11:03 am
ok, thank you for all of your help!
somercamb
Postby Maes » Mon Mar 11, 2013 2:31 pm
I can not access the website subsonic.org either. My server refuses to register it's personal web adress (HttpSocketException). I am unable to resolve any of the subsonic.org domain's except for this forum. I am unable to do so from 3 separate servers ranging from the US, UK and EU. If I cannot access the main subsonic website from 3 separate places around the globe then this leads me to believe that either the main server is down, any of it's DNS servers are down, or there's some sort of load balancing glitch going on here :D
Maes
Postby BKKKPewsey » Mon Mar 11, 2013 5:55 pm
See viewtopic.php?f=2&t=11668
There may have been an intermittent problem with the redirect service before which caused problems for the OP.
It was OK when I tested but it looked as if there where issues before & after :|
Users browsing this forum: No registered users and 66 guests
