Can't get transcoding of video to work
Postby reybr » Mon Apr 01, 2013 9:17 am
I have a problem getting video playback to work with transcoding.
The only error message i get is "Video not found or access denied" in the JW player
I'm using 4.7 (build 3105) – September 11, 2012 installed on a Synology DS212j NAS server
The only thing noted in the Subsonic log is
[4/1/13 10:00:39 AM GMT+01:00]    INFO   PlayQueueInputStream   admin listening to "music/Call Me Maybe - Carly Rae Jepsen (Chatroulette Version).mp4"
[4/1/13 10:00:39 AM GMT+01:00]    DEBUG   TranscodeInputStream   Starting transcoder: [/usr/syno/synoman/webman/3rdparty/Subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/volume1/music/Call Me Maybe - Carly Rae Jepsen (Chatroulette Version).mp4] [-async] [1] [-b] [1000k] [-s] [640x360] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-vcodec] [libx264] [-preset] [superfast] [-threads] [0] [-]
Output of ffmpeg -i from prompt
ffmpeg -i /volume1/music/Call\ Me\ Maybe\ -\ Carly\ Rae\ Jepsen\ \(Chatr
oulette\ Version\).mp4
ffmpeg version UNKNOWN, Copyright (c) 2000-2011 the FFmpeg developers
  built on Feb  7 2013 19:53:43 with gcc 4.2.1
  configuration: --arch=arm --target-os=linux --cross-prefix=/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi- --enable-cross-compile --enable-optimizations --disable-yasm --disable-altivec --enable-pic --enable-shared --disable-static --disable-swscale-alpha --disable-ffserver --disable-ffplay --enable-libmp3lame --enable-libfaac --enable-nonfree --enable-version3 --enable-libopencore-amrnb --enable-libopencore-amrwb --disable-decoder=amrnb --cc=/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-ccache-gcc
  libavutil    50. 40. 1 / 50. 40. 1
  libavcodec   52.120. 0 / 52.120. 0
  libavformat  52.108. 0 / 52.108. 0
  libavdevice  52.  4. 0 / 52.  4. 0
  libavfilter   1. 77. 0 /  1. 77. 0
  libswscale    0. 14. 0 /  0. 14. 0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/volume1/music/Call Me Maybe - Carly Rae Jepsen (Chatroulette Version).mp4':
  Metadata:
    major_brand     : mp42
    minor_version   : 0
    compatible_brands: isommp42
    creation_time   : 2012-10-19 00:56:05
  Duration: 00:03:13.53, start: 0.000000, bitrate: 1228 kb/s
    Stream #0.0(und): Video: h264 (High), yuv420p, 1280x720, 1033 kb/s, 29.97 fps, 29.97 tbr, 60k tbn, 59.94 tbc
    Metadata:
      creation_time   : 1970-01-01 00:00:00
    Stream #0.1(und): Audio: aac, 44100 Hz, stereo, s16, 192 kb/s
    Metadata:
If I turn of transcoding, it plays without problems, so the problem should be with the transcoding.
The problem is there regardless of what kind of videofile I try to transcode.
It does however transcode FLAC music files without problems, so Subsonic can start ffmpeg
Any ideas what might be the problem?
reybr
