how to upgrade to 4.8 on debian/ubuntu
Postby kpholmes » Tue Apr 23, 2013 8:42 am
do i install right over the current installation, or do i have to back up settings, uninstall 4.7, then install the new 4.8?
any help is appreciated,
thanks
kpholmes
Re: how to upgrade to 4.8 on debian/ubuntu
Postby Aethies » Tue Apr 23, 2013 2:26 pm
It would help to know what install of subsonic you are using, (i.e. WAR file, standalone, etc..)
With standalone, (that is what I use) I just overwrite the exisitng files after making a copy of the current version.
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby colli419 » Wed May 01, 2013 2:06 pm
FWIW on Debian Squeeze, if you use the standard directions:
sudo dpkg -i subsonic-version-you-want.deb
It preserves all the user data whether you are upgrading or downgrading. That said, I am unsure if this is the case with earlier versions, as I have only tried it with the last two revisions.
colli419
