Problems with Last.fm scrobble submissions?
Postby skapocalypse » Tue Apr 30, 2013 2:59 pm
Anyone else having issues with songs played not being sent to last.fm in the last few days? This has always worked just fine for me when using Subsonic, but I have noticed just recently that it seems nothing is being sent any longer. :?: :?: :?:
skapocalypse
Re: Problems with Last.fm scrobble submissions?
Postby skapocalypse » Wed May 01, 2013 9:29 pm
So...just me then? Can anyone confirm that scrobbling is still working for them? I did upgrade to version 4.8 recently, not sure if that could be the problem or not.
skapocalypse
Postby BKKKPewsey » Thu May 02, 2013 8:35 pm
Scrobbling working OK for me :|
Note sometimes Last FM's scrobble server can get overloaded - check your SS log to see if they are queued :mrgreen:
Postby sigma666 » Mon May 06, 2013 11:01 am
I'm having the same problem since upgrading to 4.8 :( The bizarre thing is that when I play music through the android app it gets scrobbled correctly (and appears in the log), but when playing through the web interface I only get "listening to..." events in the log, no song submissions or mentions of subsonic trying to submit...
EDIT: fixed
After testing scrobbling through minisub (which works) I figured it could be a problem with the player instance that was used for playback in chrome.
Deleting my web player (settings>players) and letting subsonic recreate one (I had to restart subsonic/switch browser for it to appear in chrome) fixed the scrobbling issue!
Hope this helps!
sigma666
Postby skapocalypse » Wed May 08, 2013 3:29 pm
Thanks sigma666! This was driving me nuts but doing as you described (deleting the player) fixed it right up. You have made my day!
skapocalypse
