v4.7 on Ubuntu 12: Internal error viewing newly added artist
Postby zfa » Tue May 07, 2013 4:21 am
Subsonic v4.7 on Ubuntu 12.04:
I've just added a new folder of mp3s (in the form 'artist/album/tracks.mp3') to my media folder (I only have the one folder, it contains about 750 artist folders). On trying to view it in the web interface I get an internal error in the 'main pane':
Error
Message PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
Java version Sun Microsystems Inc. 1.6.0_27
Operating system Linux 3.2.0-25-generic
Server jetty-6.1.x
Memory Used 51 of 116 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:71)
at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:152)
at net.sourceforge.subsonic.service.MediaFileService.updateChildren(MediaFileService.java:331)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:192)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:173)
at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:84)
Caused by: java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
... 62 more
Seems to be something about file size in the messages? What is this? Songs aren't overly big or anything. Any help appreciated. Similar message obtained in a popup on the Android app too.
zfa
Re: v4.7 on Ubuntu 12: Internal error viewing newly added ar
Postby alphawave7 » Tue May 07, 2013 5:14 am
Firstly I'd bump up the memory delegated to java to 250MB. Then stop the server, restart and then do a manual scan via the Settings/Search/Update Index Now link. See how that goes...
Postby zfa » Tue May 07, 2013 5:26 am
That didn't do anything in and on its own but I then deleted my media folder then re-added it, did a scan and also a clean-up of the db (just to be safe but probably unnecessary...) and I'm back up and running. I suspect your memory increase will have helped - got quite a big library.
Many thanks for your input.
zfa
Postby alphawave7 » Tue May 07, 2013 6:01 am
Good deal! Enjoy!
Users browsing this forum: Google [Bot] and 15 guests
