Port Forwarding Issues
Postby somercamb » Fri May 24, 2013 5:35 pm
anyone know why dsub will work on my Wi-Fi, but not other Wi-Fi or 3/4g? It won't connect unless on my Wi-Fi. thank you
somercamb
Re: DSub for Android
Postby daneren2005 » Fri May 24, 2013 5:39 pm
somercamb wrote:anyone know why dsub will work on my Wi-Fi, but not other Wi-Fi or 3/4g? It won't connect unless on my Wi-Fi. thank you
If it only works on your wifi and not even other's wifi then something is wrong with the routing. That is a server problem, not a app problem. You can try opening up the server in a browser to verify that you can't access it from anywhere else as well.
Postby somercamb » Fri May 24, 2013 10:22 pm
Sorry, I should have mentioned that. I just tried it and I get (in Chrome) "Oops! Google Chrome could not connect to....."
somercamb
Postby GJ51 » Sat May 25, 2013 4:48 am
Go to http://Canyouseeme.org and test to see if the port is open on the server.
Postby somercamb » Sat May 25, 2013 2:48 pm
Well, I wasn't sure what PORT # to put in, but when I went to that site, port 80 was automatically populated. Then I got :
Error: I could not see your service on 209.6.49.60 on port (80)
Reason: Connection timed out
Port 80 is the default port for http traffic. With blocked port 80 you will need to run your web server on a non-standard port in conjunction with a port 80/web redirect from No-IP.com.
HOWEVER, Under Subsonic settings/network, it states "Successfully forwarding port 80."
somercamb
Postby GJ51 » Sat May 25, 2013 2:55 pm
You need to test the port that Subsonic is using. The default should be 4040.
Postby somercamb » Sat May 25, 2013 3:07 pm
Same....
Error: I could not see your service on 209.6.49.60 on port (4040)
somercamb
Postby somercamb » Sat May 25, 2013 3:12 pm
and FYI, normally when I go to my IP address, it opens my router page. NOW, when I go to it, it goes to my subsonic page... Weird...????
somercamb
Postby somercamb » Sat May 25, 2013 3:22 pm
I tried portforward.com, but it appears the page is not working because I have chosen my router and other routers and nothing comes up, a blank page appears when choosing the router.
somercamb
Postby GJ51 » Sat May 25, 2013 3:41 pm
What OS are you on?
Have you read the tutorials?
Your port forwarding is not set correctly. You MUST get canyouseeme,org to be able to see the port as open before you can connect from outside your internal network.
viewtopic.php?f=6&t=4867
The first two posts at the link above are for Windows/Android setup, but the same principles that are explained regarding setting up the network properly apply to any OS.
Basically:
Install Subsonic on host.
Test the local host installation to see that it works on the local machine.
Try to connect from INSIDE your own network. If it doesn't work, check to see if the firewall settings on the local host machine are open for the port selected for Subsonic.
Test to see that port forwarding is properly set on your router and that no firewalls are blocking traffic to the host macine on the Subsonic port (4040).
Test from outside the network.
If the communication path is blocked anywhere the connection will fail. Your router has to pass the request from the internet to your server. If Subsonic is on a local host internally at 192.168.1.50 and is set to listen to port 4040 the router has to get a request from outside at your EXTERNAL ip:4040 and pass it to the internal address:port4040. NAT - Network address translation.
Postby somercamb » Sat May 25, 2013 3:50 pm
I will check out all of this. Thank you. I'll "report" back.
cheers :D
somercamb
Postby somercamb » Sat May 25, 2013 7:21 pm
What OS are you on? WIn7
Have you read the tutorials? I have never had to in the past. It was just like "Plug n Play". But I read over http://monroeworld.com/android/subsonic/ , but had errors at "Permissions to remote folders". At #10, am I putting in my subsonic PW? Because that is what I did. Then at #14, "OWNER-PC\Owner" was all that would work for an "object" and I then put in my subsonic PW, applied new setting, stopped service, restarted and the got "Error 1069: the service did not start due to a logon failure", where is says "You should receive no errors." I then proceeded to select Local System Account and that allowed me to start the service :(
Basically:
Install Subsonic on host. Already done. I have one PC desktop which is the host PC
Test the local host installation to see that it works on the local machine. Yes, it works. However, my address does not have "4040" in it after the colon
Try to connect from INSIDE your own network. If it doesn't work, check to see if the firewall settings on the local host machine are open for the port selected for Subsonic. INSIDE? You mean via wifi? Then yes, it works
Test to see that port forwarding is properly set on your router and that no firewalls are blocking traffic to the host macine on the Subsonic port (4040). All set, no blockage
Test from outside the network. This is where I cannot get it to work. Will not work on 3/4G or other people's wifi
If the communication path is blocked anywhere the connection will fail. Your router has to pass the request from the internet to your server. If Subsonic is on a local host internally at 192.168.1.50 and is set to listen to port 4040 the router has to get a request from outside at your EXTERNAL ip:4040 and pass it to the internal address:port4040. NAT - Network address translation. As I mentioned above, my address that works within my wifi does not contain":4040" (or :8840 like a friend of mine's site)
Thank you for all of your help. I feel dead in the water....
somercamb
Postby somercamb » Sat May 25, 2013 7:29 pm
Not sure if this matters, but my IP is supposedly 209.6.49.60, but my router has a 192.168.x.x. address for the IP and my Subsonic page opens up -on my WIFI only- whether it is http://192.168.1.126, 209.6.49.60 or somercamb.subsonic.org. The fact that it opens up with two numerical addresses, does that mean something?
And I just realized that by disabling port 80, the 206 address above gives me: 404 Not Found. File not found.
somercamb
Re: Port Forwarding Issues
Postby alphawave7 » Sat May 25, 2013 7:55 pm
Moved from DSub forum.
What port is SS using on your host? (systray_>Console). Is the host a static IP? Is your collection ON the host, or other sources?
Postby somercamb » Sat May 25, 2013 7:58 pm
port 80
not sure how to know if static or not???
videos/music is on c: and external drive. (why should that matter)?
somercamb
Users browsing this forum: No registered users and 41 guests
