how to configure with no icon?
Postby hacklan07 » Mon Jul 14, 2008 8:01 pm
Hi, I am rather excited to start using subsonic, but I've run into an issue: it doesn't seem to start when I run the start subsonic shortcut. I'm running Windows Server 2008 and already have a website setup on the computer with port forwarding etc. on my router for port 80. When I try to launch subsonic, it opens the prompt window for a split second and then it goes away. I do have the "subsonic.exe *32" process and the Subsonic service running (verified in the task manager) and I've read issues with Vista users not seeing the icon on the toolbar, so maybe that's all it is. If so, how do I configure subsonic without the icon?
hacklan07
Postby sindre_mehus » Tue Jul 15, 2008 7:44 am
You can manually edit C:\Program Files\Subsonic\subsonic.exe.vmoptions, and then restart Subsonic.
SIndre
Postby hacklan07 » Wed Jul 16, 2008 6:28 pm
Yeah, I've found that; but there aren't too many options. so i guess my question is... now that it's running, where do I go from here? Do I have to do something in MediaMonkey?
hacklan07
Subsonic not starting on Vista
Postby kirkeby » Tue Aug 05, 2008 4:38 pm
I can confirm the problem with Subsonic running on Vista. It is not just the tray icon which is disappearing, the application won't start even though the service is running. You see the DOS window flickering on the screen for a fraction of a second, then it is killed off and Subsonic is gone without a trace.
kirkeby
Postby kirkeby » Tue Aug 05, 2008 5:55 pm
Upgrading to the latest version of Java from Sun does not help.
kirkeby
No Icon and no Satrt on VISTA
Postby jeanmichael » Mon Sep 22, 2008 10:16 pm
I'am also running Vista.
No icon appears on install !
Nothing happens on subsonic start !
Anybody can help ?
Thanks, jean michael
jeanmichael
Postby jeanmichael » Mon Sep 22, 2008 10:19 pm
I precise I'm running v3.4
Anybody can help ?
jeanmichael
FYI
Postby ahrajani » Sun Sep 28, 2008 4:11 pm
FYI, there's a parallel feature requests thread called "Tray Icon" http://forum.subsonic.org/forum/viewtopic.php?t=1186
The new beta 3.5.2 does not fix the tray icon problem unfortunately.
I'm in the same boat about editing subsonic.exe.vmoptions since it has so little information in it upon a fresh install (and I'm new to the program). Anyone know of any threads where the full / partial contents of a working .vmoptions file are posted so that I can use that as a template?
ahrajani
Postby djricar2k » Thu Oct 16, 2008 4:08 pm
i am in the same problem with vista is anyone can make helps us because i would like to try subsonic;) :P :P
djricar2k
Postby djricar2k » Mon Oct 20, 2008 9:10 pm
a little up of this postto know if it was possible to have ananswer or not about the problem with vista ;)
djricar2k
