How to get Random Page to stop showing movies
Postby kyomi7502 » Fri May 31, 2013 1:21 pm
The random page I'm talking about is when you first login to your server and it displays a number of random items with coverart.
(Click "Home" and then click "Random" on the bottom left)
I thought this only showed music back in 4.6, but ever since 4.7 my video directories are getting included in this and since videos don't have embeddable cover art, it makes the random page look like it's missing cover art when it shows my video directories. Is there an option for what to include in the random listing?
Thanks.
kyomi7502
Re: How to get Random Page to stop showing movies
Postby kyomi7502 » Mon Jul 01, 2013 11:03 pm
No update at all on this? I haven't found any way of doing it yet.
kyomi7502
Postby somercamb » Sun Jul 28, 2013 4:54 pm
Hey kyomi7502, sorry to burst your bubble (I'm sure you got excited over the email notification re: this post) about posting here, but I would be interested in an answer to this as well. So...BUMP!
somercamb
Postby kyomi7502 » Sun Jul 28, 2013 6:26 pm
Hehe, yes.. indeed I did..
I remember once before that this wasn't a problem.. only since the new build (4.7) do I remember having this issue
kyomi7502
Postby somercamb » Sun Jul 28, 2013 9:19 pm
well, I just upgraded to 4.8 from 4.6 and in both versions, the RANDOM shows all content (in both versions) even though I have a separate folder for music and videos. Go figure...
somercamb
Postby GJ51 » Mon Jul 29, 2013 3:51 am
This has been an issue forevvvvver.
It just doesn't make sense that the main window would display folders that are not the currently selected folder in the left column.
If you select movies then everything in the main browser window should only display movies. If you select music then only music should show.
If you want to see everything then that's what "All Folders" should be for.
Not rocket science, but not likely to get fixed either.
Postby somercamb » Mon Jul 29, 2013 10:50 am
Or maybe have it something to change in settings, and not necessarily tied into the left column
somercamb
Postby GJ51 » Sun Aug 04, 2013 8:16 am
Or maybe tie it to something on the Sports page of your local newspaper ...
Doesn't matter - the dev isn't listening anymore.
Users browsing this forum: No registered users and 50 guests
