shuffle play on android phone broken
Postby Moe100001 » Mon Jul 15, 2013 11:42 pm
I recently did a major update to my library. I rescanned my music folder on my pc and got subsonic working fine there. My phone connects to the server fine, I can browse to a song on the library screen and play it fine. However, if I choose shuffle play from the home screen, the app will find a song, display title, but the download stays at zero and it will not play the song. If I skip songs it just does the same thing.
I tried deleting the cache and then all the app data, re-entered my server info, but it is still doing the same thing. Everything was working before I updated my library. I used mediamonkey to organize my library and made changes to the file names and tags as part of my update. I suspect it has something to do with that, but at this point am out of ideas how to figure out what I broke to make it behave like this.
Also, as part of troubleshooting this I updated to the latest server version (4.8).
Any help would be greatly appreciated!
thanks,
- M
Moe100001
Re: shuffle play on android phone broken
Postby daneren2005 » Tue Jul 16, 2013 1:30 am
Do a db cleanup from the server settings. It might just be trying to play a song it doesn't realize doesn't exist (at least not where it thinks it was) anymore
Postby Moe100001 » Tue Jul 16, 2013 8:34 pm
thanks, did that. I also just uninstalled the server and deleted the c:\subsonic directory, then re-installed and configured. Still the same thing happening. I see this error generated in the log each time I skip forward:
[7/16/13 2:28:13 PM MDT] WARN RESTFilter Error in REST API: EofException
[7/16/13 2:28:21 PM MDT] WARN RESTFilter Error in REST API: EofException
thanks,
- M
Moe100001
Postby Moe100001 » Wed Jul 17, 2013 12:21 am
To be thorough, here is the entire error message from the log. Also, I have updated both my server and android app (I have the premium version) to the latest, as I uninstalled and re-installed both. The server is running on windows 7. Please just let me know if you need any more info from me. I have really enjoyed this program and have not found any viable alternatives to streaming lossless to my phone. I gotta get this working!!
Thank you, thank you!
[2013-07-16 17:51:08,265] WARN RESTFilter - Error in REST API: EofException
org.mortbay.jetty.EofException
at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:760)
at org.mortbay.jetty.AbstractGenerator$Output.flush(AbstractGenerator.java:564)
at org.mortbay.jetty.HttpConnection$Output.flush(HttpConnection.java:907)
at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:628)
at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:575)
at net.sourceforge.subsonic.controller.StreamController.handleRequest(StreamController.java:221)
at net.sourceforge.subsonic.controller.RESTController.stream(RESTController.java:1128)
at sun.reflect.GeneratedMethodAccessor83.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at net.sourceforge.subsonic.security.RESTRequestParameterProcessingFilter.doFilter(RESTRequestParameterProcessingFilter.java:109)
at net.sourceforge.subsonic.filter.RESTFilter.doFilter(RESTFilter.java:55)
Caused by: java.io.IOException: An established connection was aborted by the software in your host machine
at sun.nio.ch.SocketDispatcher.write0(Native Method)
at sun.nio.ch.SocketDispatcher.write(Unknown Source)
at sun.nio.ch.IOUtil.writeFromNativeBuffer(Unknown Source)
at sun.nio.ch.IOUtil.write(Unknown Source)
at sun.nio.ch.SocketChannelImpl.write(Unknown Source)
at org.mortbay.io.nio.ChannelEndPoint.flush(ChannelEndPoint.java:166)
at org.mortbay.io.nio.SelectChannelEndPoint.flush(SelectChannelEndPoint.java:208)
at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:693)
Moe100001
Users browsing this forum: No registered users and 59 guests
