'$(...) is null' pop-up error
Postby GoOtterGo » Fri Aug 16, 2013 10:24 pm
Problem Description: No idea, just get that pop-up whenever I start the browser, it hasn't seemed to've affected anything.
Troubleshooting Steps: Re-installed Subsonic service, no effect.
Subsonic Version: 4.8 (build 3434) – April 17, 2013
Server Version: jetty-6.1.x, java 1.7.0_17, Windows 7 (87.4 MB / 131.1 MB)
Hardware Platform: Windows 7 Ultimate, SP1
Java Memory Limit: 500mb
Last ten log file lines:
[8/16/13 3:00:42 AM PDT]    INFO   MediaScannerService   Scanned media library with 21750 entries.
[8/16/13 3:00:43 AM PDT]    INFO   MediaScannerService   Scanned media library with 22000 entries.
[8/16/13 3:00:43 AM PDT]    INFO   MediaScannerService   Scanned media library with 22250 entries.
[8/16/13 3:00:43 AM PDT]    INFO   MediaScannerService   Scanned media library with 22500 entries.
[8/16/13 3:00:44 AM PDT]    INFO   MediaScannerService   Scanned media library with 22750 entries.
[8/16/13 3:00:44 AM PDT]    INFO   MediaScannerService   Scanned media library with 23000 entries.
[8/16/13 3:00:45 AM PDT]    INFO   MediaScannerService   Scanned media library with 23250 entries.
[8/16/13 3:00:45 AM PDT]    INFO   MediaScannerService   Scanned media library with 23500 entries.
[8/16/13 3:00:46 AM PDT]    INFO   MediaScannerService   Scanned media library with 23750 entries.
[8/16/13 3:00:47 AM PDT]    INFO   MediaScannerService   Scanned media library with 24000 entries.
GoOtterGo
Re: '$(...) is null' pop-up error
Postby elmastero » Sat Aug 16, 2014 11:19 pm
I've seen this error on every version I've used so far.
And have just put up with it.
But it's starting to drive me crazy.
From my cursory search, I can't believe there's only one mention of it.
Anyone else?
Is there a reason or a fix?
Thanks.
elmastero
Postby GJ51 » Sun Aug 17, 2014 12:40 am
I've never seen this one before. Try a browser cache clean/delete? If there's no associated error in the Subsonic log, then it's possible it could just be a browser error. Same result on different browsers? Are other users on your sight getting the same error?
Postby elmastero » Sun Aug 17, 2014 1:46 am
Weird.
I am on Linux, fwiw.
Firefox.
elmastero
Postby GJ51 » Sun Aug 17, 2014 3:26 am
Client? Server? Both?
I just logged onto one of my sites from a Linux Mint VM as the client without any problem.
Postby elmastero » Sun Aug 17, 2014 8:13 am
Client and server, actually.
I have a friend who hosts his on a Windows box and I get this message when visiting his site too.
So it must be something about Ubuntu firefox, eh?
Thanks for the response!
elmastero
Postby GJ51 » Sun Aug 17, 2014 4:28 pm
That would be my best guess. My Linux Mint VM running Firefox doesn't seem to have an issue, but it's also pretty pristine without any add ins.
You are welcome to log onto my site to see if it does the same thing in your browser.
http://mgmobil.subsonic.org
use guest for access
The site is the 5.0 beta1 - but if you see the same behavior, then you can assume it's a browser issue.
Postby Fangs404 » Thu Jan 22, 2015 6:39 pm
I wanted to bump this. I'm seeing the same thing, and I'm using Firefox 35 on OS X 10.9.5, so it's not just a Linux thing. I've gotten this for a very long time (been a Subsonic user for several years now). The weird thing is that it doesn't happen every time I open Firefox; it maybe happens 50-60% of the time. I do have Subsonic pinned as a tab in FF, but I have no idea if that would affect anything.
Here's a screenshot: http://i.imgur.com/g0vPVgY.png
Notice that nothing in the background has loaded (artwork, the player down at the bottom, etc.). When I click OK, everything loads as if there were no error.
Fangs404
Postby elmastero » Thu Jan 22, 2015 6:55 pm
Here's my theory........
In my Firefox prefs, I've set FF to automatically open a good 5 or 6 tabs (2 of which are Subsonic tabs).
I have a feeling that '$' is not defined yet since FF is busy opening a bunch of tabs, etc.
I've thought about creating a Greasemonkey script that either delays the Subsonic tabs a bit (using setTimeout or something) or actually making sure to load jquery (or whatever js library Subsonic uses before doing anything else....BTW, what does Subsonic use??)
But yeah......pretty annoying. It's really my only beef with Subsonic though.
elmastero
Postby Fangs404 » Thu Jan 22, 2015 7:05 pm
elmastero wrote:Here's my theory........
That's actually exactly what I was thinking. It seems like something that Subsonic is expecting to be ready isn't ready when Firefox tells Subsonic to load.
Fangs404
Postby Fangs404 » Thu Jan 22, 2015 7:06 pm
FYI, I posted a bug on SourceForge here just to make sure the devs are aware of this issue and have an official way to track it.
Fangs404
Postby elmastero » Thu Jan 22, 2015 7:15 pm
Awesome!
Thanks, Fangs!!
elmastero
Postby daneren2005 » Thu Jan 22, 2015 8:44 pm
Probably just something not in a document ready
Postby sindre_mehus » Thu Jan 22, 2015 10:26 pm
Is there anything in the Firefox error console?
Postby sindre_mehus » Sat Jan 24, 2015 5:12 pm
I found some dodgy javascript in the page showing "now playing" and chat. This could be the cause. Fixed it now.
Users browsing this forum: No registered users and 44 guests
