new cable modem/wireless router
Postby chefdwsaute » Sun Oct 13, 2013 1:15 am
Hi all,
Time Warner Cable has upgraded my internet and I will be picking up a new cable modem/wireless router on Monday. My question is will I need to change any settings or will I be able to just switch out the old modem/router and carry on as usual. I know this sounds like a dumb question but I'm still somewhat new at this. Any help would be appreciated. Thank you, David
chefdwsaute
Re: new cable modem/wireless router
Postby gurutech » Sun Oct 13, 2013 4:38 am
Do you have a second router that you have connected to the cable modem, with everything else connected to the router, or does everything connect to the cable modem?
(In other words, where is your port forwarding set up - on the cable modem or on a separate router?
gurutech
Postby chefdwsaute » Sun Oct 13, 2013 5:06 am
currently i have an all in one cable modem/wireless router. they are moving me up a notch (20mbps to 30mbps) and giving me digital phone service also. i assume it will be an all in one unit again.
chefdwsaute
Postby chefdwsaute » Sun Oct 13, 2013 7:25 am
port forwarding is on cable modem which is also the wireless router
chefdwsaute
Postby chefdwsaute » Sun Oct 13, 2013 5:04 pm
here are my port forwarding settings on the modem/router currently:
Index- Local IP - Internal Port - Public Interface IP- Ext Start Port - Ext End Port - Protocol - Enabled
1- 192.168.0.150 - 80- 75.181.12.244 - 80- 80- both - yes
2 - 192.168.0.150 - 4040 - 75.181.12.244 - 4040- 4040 - both - yes
3 - 192.168.0.150 - 4443- 75.181.12.244 - 4443- 4443 - both - yes
so basically, my question is can i use these same settings on the new cable modem/wireless router when i pick it up tomorrow? or am i going to have to figure out all new settings?
once again, this is still something i'm learning. Subsonic is working fine with these modem/router settings and i'm hoping i can just put these same settings into the new modem/router and everything will function the same. thank you again for your help. David
chefdwsaute
Postby chefdwsaute » Sun Oct 13, 2013 5:05 pm
and sorry those current settings posted without the spaces that i had before i submitted that response. i just added some dashes to separate the columns to make it a little easier to understand. thanx again, David
chefdwsaute
Postby gurutech » Mon Oct 14, 2013 1:23 am
The public interface IP address will most likely change with the new cable modem unless you are paying for a static IP Address from your ISP.
gurutech
Postby chefdwsaute » Mon Oct 14, 2013 1:34 am
thank you. i do understand that. all other settings should be the same though, yes?
chefdwsaute
Postby gurutech » Mon Oct 14, 2013 3:45 am
Yep, you shouldn't need to make any changes to Subsonic.
If you have any DynDNS or No-IP settings, you may need to manually update them though once you have your new IP address, but that's about it.
gurutech
Postby chefdwsaute » Mon Oct 14, 2013 4:38 am
thank you gurutech! hopefully it will all go smoothly tomorrow. i will post my results after i install the new modem/router. thank you again! David
chefdwsaute
Postby chefdwsaute » Mon Oct 14, 2013 8:22 pm
thank you again gurutech! all i had to do was set up virtual server for each port on my new modem/router and it worked like a charm. this networking/port forwarding thing gets a little easier each time i have to muscle thru it. once again, thank you for all of your help! David
chefdwsaute
Users browsing this forum: Google [Bot] and 28 guests
