OS X Mavericks: Subsonic fails to start up
Postby vandiss » Wed Oct 23, 2013 11:18 am
Since installing Mavericks on my Mac, Subsonic has failed to start up.
Looking in the logs, I see the following error:
23/10/2013 13:07:31.809 Dock[490]: LSOpenFromURLSpec(file:///Applications/Subsonic.app/) failed with -10658
I also tried from command line with the same result:
$ open Subsonic.app
LSOpenURLsWithRole() failed with error -10658 for the file /Applications/Subsonic.app.
I've tried reinstalling 4.8, but still get the same error message.
Is there a workaround?
vandiss
Re: OS X Mavericks: Subsonic fails to start up
Postby gurutech » Wed Oct 23, 2013 1:24 pm
Try this command:
chmod +x /Applications/Subsonic.app/Contents/MacOS/subsonic
You may need to set the file to "executable" mode using the above line.
gurutech
Postby vandiss » Wed Oct 23, 2013 2:10 pm
Hi, that file doesn't exist in my installation...
Here are the files I have under Subsonic.app/Contents/...
$ ls -lR
total 16
-rw-rw-r--  1 root  admin  2087 17 Apr  2013 Info.plist
drwxrwxr-x  3 root  admin   102 23 Oct 13:05 MacOS
-rw-rw-r--  1 root  admin     9 17 Apr  2013 PkgInfo
drwxrwxr-x  5 root  admin   170 23 Oct 13:05 Resources
./MacOS:
total 72
-rwxrwxr-x  1 root  admin  35072 17 Apr  2013 JavaApplicationStub
./Resources:
total 40512
drwxrwxr-x  3 root  admin       102 23 Oct 13:05 Java
-rw-rw-r--  1 root  admin     88112 17 Apr  2013 subsonic.icns
-rw-rw-r--  1 root  admin  20650059 17 Apr  2013 subsonic.war
./Resources/Java:
total 21104
-rw-rw-r--  1 root  admin  10801883 17 Apr  2013 subsonic-booter-jar-with-dependencies.jar
I'll try running DiskUtility and see if that clears up any permissions problems...
vandiss
Postby vandiss » Fri Oct 25, 2013 2:23 pm
Turns out not to be a Mavericks problem, but Java...
I "downgraded" from 1.7 to 1.6.0_65 and Subsonic works no problem!
vandiss
Postby gurutech » Fri Oct 25, 2013 10:25 pm
May want to take a look at Madsonic, which is built upon Subsonic. It has a lot more features, and will run on Java 1.7 with no issues.
gurutech
Postby gipsycat » Mon Mar 03, 2014 7:34 am
@vandiss, how did you downgrade your java?
I cannot find a link to the old build anywhere ...
gipsycat
Postby vandiss » Mon Mar 03, 2014 7:45 am
Hi, follow the instructions here. They work on Mavericks just as well as 10.8...
http://superuser.com/questions/490425/h ... s-x-10-8-2
vandiss
