Virus Detected?
Virus Detected?
Postby ebdcs » Wed Oct 08, 2008 8:04 pm
Sidre mehus,
Congratulations on the excellent software multimedia stream. Soon be sending the translation into Portuguese (Brazil).
I'm reporting an indication of virus in the file "subsonic-3.5.beta2-setup" as Win32: Rbot-MDS (Backdoor), detected by Avast! Pro v4.8.1229 Bank of virus 08.10.2008
Please check.
Thank you.
Emmerson BD Castro (ebdcs)
Ps. It used a translator.
ebdcs
Postby sindre_mehus » Thu Oct 09, 2008 8:37 am
Hi Emmerson,
Thanks for reporting this. I also use Avast and get the same result if I scan subsonic-3.5.beta2-setup.exe. After some digging I found that the virus alert comes from the bundled transcoder which installs in c:\subsonic\transcode\faad.exe. However, if I scan this file directly no virus alert is given - so it's probably a false alert.
Anyway, I've updated the transcoding pack with a new version of faad.exe which works with Avast. It can be downloaded here: http://subsonic.sourceforge.net/transcode.html
Also, the upcoming 3.5 release will contain this new version of faad.exe.
Thanks again, and looking forward to the Portuguese translation!
SPR/SimpleFirewallC
Postby BlueScorpion » Sun Oct 25, 2009 11:02 am
Hello Sindre,
what a great software you're developing... Thanks a lot!
Since I use Subsonic, started with v3.7, my "Avira Antivirus" found SPR/SimpleFirewallC.
Now I use the new v3.8 but these warning still appear.
During the installation the following issues were found:
subsonic-3.8-setup.exe' -> SPR/SimpleFirewallC' [riskware]
SimpleFC.dll -> SPR/SimpleFirewallC' [riskware] (in my temp-folder)
After Installation this one is left:
uninstall.exe-> SPR/SimpleFirewallC' [riskware] (in program-folder)
Maybe you can check it out too? :)
Thank you!
Greetings
Matthias
http://drehmomente.com.de
BlueScorpion
