DLNA just expands more and more, eg audio/audio/audio/audio
Postby leekthrow » Thu Jan 30, 2014 1:05 am
It does the same thing for me in foobar2000, xbmc, and my pioneer receiver. This shot is from the foobar2000 browser: Image
I decided to pull down the older war files from sf.net... it works in 4.9-beta2
4.9-beta2 I get a list of artists and I can navigate to the files as expected to play them.
4.9-beta3 I get the same endless "audio" directory as with 4.9
4.9-beta4 gives the endless "audio" directory as well.
Subsonic Version: 4.9 (build 3819) – January 23, 2014
Server Version: jetty/8.1.11.v20130520, java 1.7.0_25, FreeBSD (136.3 MB / 207.1 MB)
To get ss to run under jetty, I followed the steps in http://forum.subsonic.org/forum/viewtopic.php?f=6&t=10197
Hardware Platform: FreeBSD 10.0-RELEASE
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
ffmpeg version 2.1.1 Copyright (c) 2000-2013 the FFmpeg developers
  built on Jan 29 2014 19:40:45 with FreeBSD clang version 3.3 (tags/RELEASE_33/final 183502) 20130610
  configuration: --enable-libaacplus --disable-indev=alsa --disable-outdev=alsa --disable-libopencore-amrnb --disable-libopencore-amrwb --disable-libass --disable-libcdio --disable-libcelt --enable-libfaac --disable-libfdk-aac --enable-ffserver --enable-fontconfig --enable-libfreetype --enable-frei0r --enable-gnutls --disable-libgsm --enable-iconv --disable-indev=jack --enable-libmp3lame --disable-libbluray --disable-libv4l2 --disable-indev=v4l2 --disable-outdev=v4l2 --disable-libmodplug --disable-openal --disable-indev=openal --enable-libopencv --enable-libopenjpeg --disable-libopus --disable-libpulse --disable-indev=pulse --disable-outdev=pulse --disable-librtmp --enable-libschroedinger --disable-libspeex --enable-libtheora --disable-vaapi --disable-vdpau --enable-libvorbis --disable-libvo-aacenc --disable-libvo-amrwbenc --enable-libvpx --enable-libx264 --enable-libxvid --prefix=/usr/local --mandir=/usr/local/man --datadir=/usr/local/share/ffmpeg --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-avresample --enable-pthreads --enable-memalign-hack --disable-libstagefright-h264 --disable-libutvideo --disable-libsoxr --cc=cc --extra-cflags='-msse -I/usr/local/include/vorbis -I/usr/local/include' --extra-ldflags='-L/usr/local/lib ' --extra-libs=-pthread --disable-debug --disable-ffplay --disable-outdev=sdl --enable-nonfree
  libavutil      52. 48.101 / 52. 48.101
  libavcodec     55. 39.101 / 55. 39.101
  libavformat    55. 19.104 / 55. 19.104
  libavdevice    55.  5.100 / 55.  5.100
  libavfilter     3. 90.100 /  3. 90.100
  libavresample   1.  1.  0 /  1.  1.  0
  libswscale      2.  5.101 /  2.  5.101
  libswresample   0. 17.104 /  0. 17.104
  libpostproc    52.  3.100 / 52.  3.100
[mp3 @ 0x808c3a420] Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from '01 - Capricorn (A Brand New Name).mp3':
  Metadata:
    title           : Capricorn (A Brand New Name)
    artist          : 30 Seconds to Mars
    track           : 1/12
    album           : 30 Seconds to Mars
    disc            : 1/1
    TMED            : CD
    SCRIPT          : Latn
    MusicBrainz Album Type: album
    MusicBrainz Album Artist Id: d8354b38-e942-4c89-ba93-29323432abc3
    MusicBrainz Artist Id: d8354b38-e942-4c89-ba93-29323432abc3
    MusicBrainz Album Status: official
    TSO2            : 30 Seconds to Mars
    album_artist    : 30 Seconds to Mars
    TORY            : 2002
    artist-sort     : 30 Seconds to Mars
    MusicBrainz Album Release Country: US
    MusicBrainz Album Id: c3b239c6-60fd-4798-99d8-a0373147d779
    publisher       : Immortal Records
    date            : 2002-08-27
  Duration: 00:03:51.18, start: 0.000000, bitrate: 192 kb/s
    Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16p, 192 kb/s
Last ten log file lines:
[1/30/14 12:44:30 AM GMT]   INFO   VersionService   Resolved latest Subsonic final version to: 4.9
[1/30/14 12:44:30 AM GMT]   INFO   VersionService   Resolved latest Subsonic beta version to: 4.9.beta4
[1/30/14 12:44:34 AM GMT]   WARN   NetworkService   No UPnP router found.
[1/30/14 12:45:32 AM GMT]   INFO   FolderBasedContentDirectory   UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 1000
[1/30/14 12:45:33 AM GMT]   INFO   FolderBasedContentDirectory   UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 1000
[1/30/14 12:45:34 AM GMT]   INFO   FolderBasedContentDirectory   UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 1000
[1/30/14 12:45:35 AM GMT]   INFO   FolderBasedContentDirectory   UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 1000
[1/30/14 12:47:26 AM GMT]   INFO   FolderBasedContentDirectory   UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 1000
[1/30/14 12:47:27 AM GMT]   INFO   FolderBasedContentDirectory   UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 1000
[1/30/14 12:49:24 AM GMT]   INFO   PodcastService   Starting scheduled Podcast refresh.
[1/30/14 12:49:24 AM GMT]   INFO   PodcastService   Completed scheduled Podcast refresh.
leekthrow
Re: DLNA just expands more and more, eg audio/audio/audio/au
Postby mjarends » Fri Jan 31, 2014 7:10 pm
I have the exact same issue as the original poster. I installed mine using the install file. As the original poster said it was working fine up until the 2nd beta. After that I continued to see the behavior that is described above. I can provide additional logs if needed. I have tested with both Windows 8.1 File Explorer and the Android MediaBrowser app, both of these had worked up until beta 2. Additionally I have noticed that if I enable DLNA on the server, the server eventually consumes more and more memory (possible memory leak?) and then eventually becomes hung. I am running my server on Windows Home Server 2011.
Version 4.9 (build 3853) – January 23, 2014
Server jetty-6.1.x, java 1.7.0_11, Windows Server 2008 R2 (45.9 MB / 77.0 MB)
mjarends
Postby adamrabin » Fri Feb 07, 2014 11:11 am
Me too. I'm using a Sony blu-ray player that has Netflix, Hulu, and a bunch of other web stuff.
On the Sony I navigate to Music > Subsonic > Music > Music > Music ... etc.
Windows 7
Subsonic 4.9 (build 3853) – January 23, 2014 - Windows Installer
Sony Blu-ray player
adamrabin
Postby MrPeabody » Sat Feb 08, 2014 3:15 pm
I updated to 4.9 this morning and am receiving the same error on a Sony DLNA TV as well.
Part of my log includes:
--------------snip---------------------
[2/8/14 10:08:13 AM EST] ERROR FolderBasedContentDirectory UPnP error: java.lang.NumberFormatException: For input string: "music/all"
[2/8/14 10:08:13 AM EST] INFO FolderBasedContentDirectory UPnP request - objectId: music/all, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 50
[2/8/14 10:08:13 AM EST] INFO FolderBasedContentDirectory UPnP request - objectId: picture/all, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 50
[2/8/14 10:08:13 AM EST] ERROR FolderBasedContentDirectory UPnP error: java.lang.NumberFormatException: For input string: "picture/all"
[2/8/14 10:08:13 AM EST] INFO FolderBasedContentDirectory UPnP request - objectId: music/all, browseFlag: BrowseMetadata, filter: *, firstResult: 0, maxResults: 1
[2/8/14 10:08:13 AM EST] INFO FolderBasedContentDirectory UPnP request - objectId: picture/all, browseFlag: BrowseMetadata, filter: *, firstResult: 0, maxResults: 1
[2/8/14 10:08:13 AM EST] INFO FolderBasedContentDirectory UPnP request - objectId: video/all, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 50
[2/8/14 10:08:13 AM EST] ERROR FolderBasedContentDirectory UPnP error: java.lang.NumberFormatException: For input string: "video/all"
[2/8/14 10:08:13 AM EST] INFO FolderBasedContentDirectory UPnP request - objectId: video/all, browseFlag: BrowseMetadata, filter: *, firstResult: 0, maxResults: 1
[2/8/14 10:08:14 AM EST] INFO FolderBasedContentDirectory UPnP request - objectId: video/all, browseFlag: BrowseMetadata, filter: *, firstResult: 0, maxResults: 1
[2/8/14 10:08:14 AM EST] ERROR FolderBasedContentDirectory UPnP error: java.lang.NumberFormatException: For input string: "video/all"
[2/8/14 10:08:29 AM EST] INFO FolderBasedContentDirectory UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 50
[2/8/14 10:08:36 AM EST] INFO FolderBasedContentDirectory UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 50
--------------------------------snip-----------------------------
Music in particular simply bounces to the next and the next until an error comes on screen indicating reaching the limit to nesting.
MrPeabody
Postby freekdb » Mon Feb 17, 2014 1:25 pm
I'm having the same issue, on DLNA clients in Android and Windows. So it's definitely a problem in Subsonic.
It's a shame, I'm really exited about subsonic having DLNA support.
I read that this issue has been introduced after beta 2. I guess I'll go back to beta 2 and wait until this issue is fixed.
freekdb
Postby jmille8934 » Sat Mar 01, 2014 2:48 pm
i am having the same issue - is there something that i have done incorrectly in the set up, or is this an issue with the code? It would be great if you could just stream the subsonic player to a DLNA renderer, but i can't figure out how to make that happen.
jmille8934
Postby jt81951 » Sat Mar 01, 2014 3:11 pm
Having the same issue here... is there any official response to this yet? DLNA was a pretty big new feature, and now to not have it work correctly with the final version is frustrating. I am running on Ubuntu Server 12.04 and performed the upgrade via debian/ubuntu installer when 4.9 was released (so went direct from 4.8 to 4.9). Wondering if others having the problem have a similar configuration? Thanks.
jt81951
Postby reitermaniac » Wed Mar 12, 2014 9:11 am
I'm using subsonic 4.9 on debian wheezy with tomcat 6 and have the same problem. Browsing my main music folder ends up in an endless recursion call. Two other folders are browseable. This main folder contains the most of my music ~ 1000 files. Is it possible that the size of the dir's is a problem?
reitermaniac
Postby RecceDG » Wed Mar 12, 2014 5:38 pm
RecceDG
Postby ecd1973 » Fri Mar 14, 2014 12:04 pm
This is happening to me as well viewing from Playstation 3. The main audio folder recursively just keeps displaying with no tracks.
ecd1973
Postby nomi34 » Sun Mar 16, 2014 4:49 am
Same issue here running Subsonic 4.9 (build 3853). Installed using apt on Ubuntu. Client end is Windows 8.1 and a Yamaha AV. Note that it also only does that on my Music directory. I can navigate my video directory fine. I even tried removing the audio directory and re-adding (and rescan) but it didn't fix the issue.
Sent from my GT-I9505G using Tapatalk
nomi34
Postby RecceDG » Sun Mar 16, 2014 11:31 am
So has anyone heard from the developer?
I'm considering stepping up and paying for the premium version, but not if this is the level of feedback and response...
RecceDG
Postby RecceDG » Mon Mar 17, 2014 10:41 am
OK, I bought 2 years of Premium.
Now can we get this fixed?
RecceDG
Postby RecceDG » Fri Mar 21, 2014 10:32 am
Bump. Problem still exists....
RecceDG
Postby NyvenZA » Sun Mar 23, 2014 10:00 am
Just upgraded from 4.7 to 4.9 and I am using Ubuntu Server 13.04 64 bIt.
I also have the same issue.
I can access the DLNA server from Yatse (XBMC Android Remote) and I can get to the first level of the Music share and it just doesn't go further than that entry. My Shared location is /mnt/drive4/Music/Organized and the first entry in the DLNA tree is "Organized". If I click on it, it just shows the same name again.
NyvenZA
Users browsing this forum: No registered users and 80 guests
