Subsonic not finding new additions
Postby richard127 » Thu Feb 13, 2014 12:15 pm
This is getting very frustrating. Subsonic has started to not display any new albums added to my music media folder. Always worked fine in the past but now I constantly have to go through the following procedure (as recommended by another subsonic forum user): Un-check the media folders, Save, rescan, clean db, rescan, recheck folders, and then rescan.
Whilst this works ok, I have to re-do it every time I add anything new. I'm using Windows 7 and my media is on an external HD. Pretty standard setup really and I haven't had problems in the past. I know others have had this problem but no-one seems to have come up with a cast-iron reason for it or a sure-fire, permanent solution. I also use Bubble upnp which isn't as feature rich but at least it works. I may have to switch permanently if this isn't fixed.
Anyone got any ideas?
richard127
Re: Subsonic not finding new additions
Postby interr0bangr » Fri Feb 14, 2014 6:12 am
Sounds exactly like my problem that I posted about here: viewtopic.php?f=2&t=14036
Super frustrating.
interr0bangr
Users browsing this forum: Google [Bot] and 29 guests
