Abnormal MP4 Issue (JAudioTagger)
Postby Hobl » Thu Feb 27, 2014 11:47 pm
Problem Description: When adding an MP4-based podcast (such as the Jaytech Music Podcast) files download then get an error saying they are corrupt, even though they play fine in MPC-HC, VNC, and even the Windows 8 metro Music app.
Troubleshooting Steps: Looked through logs, found links to JAudioTagger. Looked through JAudioTagger JIRA which suggests this issue was encountered in an older version of JAT.
Playback Application and version: N/A as I cannot even get to the stage of playing the Podcast through Subsonic.
Subsonic Version: 4.9 (build 3853) – January 23, 2014
Server Version: jetty-6.1.x, java 1.7.0_51, Linux (56.3 MB / 324.0 MB)
Hardware Platform: Linux (CentOS v5.9, latest packages via yum update)
Java Memory Limit: 100MB
Problem Filename: The most recent 10+ podcasts from this feed among others-- http://jaytechmusic.com/jaytechmusic/jaytechmusic.xml
Output from ffmpeg -i: The file is deleted upon failing in Subsonic, though I have run this on a copy I downloaded from the same source, on the same machine outside of Subsonic (via wget).
[mxhob1@erebos Jaytech Music Podcast]$ sudo ffmpeg -i Jaytech\ Music\ Episode\ 074.m4a
FFmpeg version 0.6.5, Copyright (c) 2000-2010 the FFmpeg developers
  built on Jan 29 2012 17:52:15 with gcc 4.4.5 20110214 (Red Hat 4.4.5-6)
  configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --mandir=/usr/share/man --incdir=/usr/include --disable-avisynth --extra-cflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -fPIC' --enable-avfilter --enable-avfilter-lavf --enable-libdc1394 --enable-libdirac --enable-libfaac --enable-libfaad --enable-libfaadbin --enable-libgsm --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libx264 --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-shared --enable-swscale --enable-vdpau --enable-version3 --enable-x11grab
  libavutil     50.15. 1 / 50.15. 1
  libavcodec    52.72. 2 / 52.72. 2
  libavformat   52.64. 2 / 52.64. 2
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.19. 0 /  1.19. 0
  libswscale     0.11. 0 /  0.11. 0
  libpostproc   51. 2. 0 / 51. 2. 0
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x2340670]max_analyze_duration reached
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Jaytech Music Episode 074.m4a':
  Metadata:
    major_brand     : M4A
    minor_version   : 1
    compatible_brands: M4A mp42isom
    title           : Jaytech Music Episode 074
    artist          : Jaytech
    album           : Jaytech Music Podcast
    encoder         : GarageBand 6.0.5
    date            : 2014
    comment         : The February 2014 episode of Jaytech Music features new tracks from Cramp, Ilan Bluestone and Blend, as well as Jaytech’s new collaboration with Super8 & Tab. Guest mix this month courtesy of Anjunabeats producer Maor Levi.
  Duration: 01:57:10.70, start: 0.000000, bitrate: 194 kb/s
    Chapter #0.0: start 0.000000, end 359.965000
    Metadata:
      title           : Igor Voevodin - Odyssey (Ewan Rill Remix) [Dextrous Records]
    Chapter #0.1: start 359.965000, end 644.971667
    Metadata:
      title           : Something Good & Caps - Brand New Day [Nocturnal Groove]rds]
    Chapter #0.2: start 644.971667, end 944.983333
    Metadata:
      title           : Cramp - QWERTY [Intricate Records]
    Chapter #0.3: start 944.983333, end 1304.951667
    Metadata:
      title           : EDU & Kristoffer Ljungberg - Around the Sun (Funtom Cruisers Remix) [Macarize]
    Chapter #0.4: start 1304.951667, end 1575.005000
    Metadata:
      title           : Andre Sobota & Jamie K - Polarity [Monster Tunes]
    Chapter #0.5: start 1575.005000, end 1949.983333
    Metadata:
      title           : Azotti - The Miracle (Kago Pengchi Remix) [Mondo Records]
    Chapter #0.6: start 1949.983333, end 2279.936667
    Metadata:
      title           : Sebastian Krieg - Apollonia vs. Everything But The Girl- Wrong (Wherever You Go) [Realbasic Recordings]
    Chapter #0.7: start 2279.936667, end 2668.063333
    Metadata:
      title           : Suspect 44 - The End (Blend pres. Volant Remix) [Intricate Records]▒
    Chapter #0.8: start 2668.063333, end 2969.893333
    Metadata:
      title           : Mark Nails feat Molly Bancroft - Open Your Eyes (Dub Mix) [Alter Ego]Macarize]
    Chapter #0.9: start 2969.893333, end 3284.791667
    Metadata:
      title           : ilan Bluestone - Spheres [Anjunabeats]!
    Chapter #0.10: start 3284.791667, end 3619.816667
    Metadata:
      title           : Super8 & Tab vs Jaytech - ID [ID]
    Chapter #0.11: start 3619.816667, end 3819.368333
    Metadata:
      title           : Rebecca & Fiona feat. Vice - Hot shots [M]
    Chapter #0.12: start 3819.368333, end 4104.311667
    Metadata:
      title           : Todd Terry Pres. CLS - Can You Feel It (Prok & Fitch Remix) [Strictly Rhythm]]
    Chapter #0.13: start 4104.311667, end 4344.410000
    Metadata:
      title           : Sgt. Slick - Got to Love Somebody (West Coast Mix) [Vicious]
    Chapter #0.14: start 4344.410000, end 4591.901667
    Metadata:
      title           : Norin & Rad - Thundercat [Anjunabeats]
    Chapter #0.15: start 4591.901667, end 4854.380000
    Metadata:
      title           : Daddy's Groove - Miners [Ultra]
    Chapter #0.16: start 4854.380000, end 5086.618333
    Metadata:
      title           : AN21, Dimitri Vangelis & Wyman - Rebel [Size]
    Chapter #0.17: start 5086.618333, end 5307.921667
    Metadata:
      title           : Tom Staar - Rocket [Toolroom Records]l [Size]
    Chapter #0.18: start 5307.921667, end 5495.380000
    Metadata:
      title           : Alex Clare - Sanctuary (Maor Levi Remix) [ID]
    Chapter #0.19: start 5495.380000, end 5832.868333
    Metadata:
      title           : Adventure Club feat. Yuna - Gold (LAZER LAZER LAZER Remix)[ID]
    Chapter #0.20: start 5832.868333, end 6072.983333
    Metadata:
      title           : James Blunt - Bonfire Heart (Flatdisk Remix) [Big Beat]ix)[ID]
    Chapter #0.21: start 6072.983333, end 6429.096667
    Metadata:
      title           : Morgan Page feat. Michael S - Against The World (Denzal Park Remix) [Nettwerk]
    Chapter #0.22: start 6429.096667, end 6699.145000
    Metadata:
      title           : London Grammar - Hey Now (Arty Remix) [Ministry Of Sound])[ID]
    Chapter #0.23: start 6699.145000, end 7030.700000
    Metadata:
      title           : Passion Pit - Let Your Love Grow Tall (Maor Levi's Starlight Mix) [ID]ettwerk]
    Stream #0.0(eng): Subtitle: tx3g / 0x67337874, 0 kb/s
    Stream #0.1(eng): Audio: aac, 44100 Hz, stereo, s16, 191 kb/s
    Stream #0.2(eng): Video: mjpeg, yuvj444p, 300x300 [PAR 72:72 DAR 1:1], 0 kb/s, 0k fps, 600 tbr, 600 tbn, 600 tbc
Last ten log file lines:
[2/28/14 7:33:11 PM EST]   WARN   JaudiotaggerParser   Error when parsing tags in /mnt/raid5/Music/Podcasts/Jaytech Music Podcast/Jaytech%20Music%20Episode%20074.m4a
[2/28/14 7:33:11 PM EST]   WARN   JaudiotaggerParser   Error when parsing tags in /mnt/raid5/Music/Podcasts/Jaytech Music Podcast/Jaytech%20Music%20Podcast%20073.m4a
[2/28/14 7:33:11 PM EST]   WARN   JaudiotaggerParser   Error when parsing tags in /mnt/raid5/Music/Podcasts/Jaytech Music Podcast/JaytechMusicPodcast072.m4a
[2/28/14 7:34:00 PM EST]   WARN   JaudiotaggerParser   Error when parsing tags in /mnt/raid5/Music/Podcasts/Jaytech Music Podcast/Jaytech%20Music%20Episode%20074.m4a
[2/28/14 7:34:00 PM EST]   INFO   PodcastService   Downloaded 170674389 bytes from Podcast http://jaytechmusic.com/sites/default/files/podcasts/Jaytech%20Music%20Episode%20074.m4a
[2/28/14 7:34:00 PM EST]   WARN   JaudiotaggerParser   Failed to update tags for file Jaytech%20Music%20Episode%20074
[2/28/14 7:34:00 PM EST]   WARN   PodcastService   Failed to download Podcast from http://jaytechmusic.com/sites/default/files/podcasts/Jaytech%20Music%20Episode%20074.m4a
[2/28/14 7:34:00 PM EST]   INFO   PodcastService   Starting to download Podcast from http://jaytechmusic.com/sites/default/files/podcasts/Jaytech%20Music%20Podcast%20071.m4a
[2/28/14 7:34:02 PM EST]   WARN   JaudiotaggerParser   Error when parsing tags in /mnt/raid5/Music/Podcasts/Jaytech Music Podcast/JaytechMusicPodcast072.m4a
[2/28/14 7:34:02 PM EST]   INFO   PodcastService   Downloaded 174351781 bytes from Podcast http://jaytechmusic.com/sites/default/files/podcasts/JaytechMusicPodcast072.m4a
[2/28/14 7:34:02 PM EST]   WARN   JaudiotaggerParser   Failed to update tags for file JaytechMusicPodcast072
[2/28/14 7:34:02 PM EST]   WARN   PodcastService   Failed to download Podcast from http://jaytechmusic.com/sites/default/files/podcasts/JaytechMusicPodcast072.m4a
[2/28/14 7:34:02 PM EST]   INFO   PodcastService   Starting to download Podcast from http://jaytechmusic.com/sites/default/files/podcasts/JaytechMusicPodcast070.m4a
[2/28/14 7:34:06 PM EST]   WARN   JaudiotaggerParser   Error when parsing tags in /mnt/raid5/Music/Podcasts/Jaytech Music Podcast/Jaytech%20Music%20Podcast%20071.m4a
[2/28/14 7:34:06 PM EST]   WARN   JaudiotaggerParser   Error when parsing tags in /mnt/raid5/Music/Podcasts/Jaytech Music Podcast/JaytechMusicPodcast070.m4a
This problem is absolutely driving me crazy :(
Last Subsonic box I had a few months ago was running v4.7 and I had this podcast added without issue.
Any ideas guys?
Hobl
Re: Abnormal MP4 Issue (JAudioTagger)
Postby Hobl » Wed Mar 05, 2014 8:32 pm
Bump?
Hobl
Postby daneren2005 » Wed Mar 05, 2014 10:24 pm
I added the podcast and had the same issue. I tried update the version of jaudioparser, and it still throws the same error (though it did seem to fix some of the issues I was previously having with certain files). While looking through the ffmpeg log you put there, it looks like it is actually a video file:
M4a is a audio file format. The podcast feed needs to report it is a video, not a audio file so that Subsonic doesn't try to look for audio tags on a video file.
Postby spookybathtub » Fri Mar 07, 2014 3:44 pm
That line just means ffmpeg detects the 300px album artwork in a file. To avoid those warnings you can add "-vn" to the transcode options.
Everything you posted from that log is a warning, I don't see any errors. You're using a very old version of ffmpeg, you might fix the warnings by upgrading it to a recent build. What happens exactly when you try to play this file in Subsonic?
spookybathtub
Postby Hobl » Sun Mar 09, 2014 8:29 pm
I didn't realize CentOS came with such an old version of ffmpeg! I've built it from source now and am currently on ffmpeg version N-61202-g8dfd0e6.
Unfortunately neither that or adding -vn resolved the issue. If it was just this one podcast it would be alright but it's any podcast with m4a files in it (despite it saying 'not a valid mp4 file'). I've even got a couple where they have swapped to m4a's and I have all the backlog of mp3 episodes and all the m4a's are errored out :( Also, the file plays through the Subsonic web player both from the Podcast management section and the actual Podcast folder, so it's definitely only an issue with the tags being read out of the files...
If I were to build Subsonic from source could I merge in the current source of JAudioTagger without issue do you think?
Hobl
Postby Hobl » Mon Mar 24, 2014 2:38 pm
Anybody have any further ideas? :cry:
Hobl
Postby daneren2005 » Mon Mar 24, 2014 2:50 pm
If your willing to build from source I was able to fix the issue with the change to PodcastService on https://github.com/daneren2005/Subsonic ... 794b2af0e0. I tried updating to the latest jaudiotagger version, but that didn't fix it.
Postby spookybathtub » Mon Mar 31, 2014 12:25 am
I tried downloading that podcast, and I see the same errors, but the episodes still play fine; not sure why they would get automatically deleted on your system. The only problem I see with playing these files in Subsonic is the progress bar is inaccurate.
spookybathtub
Users browsing this forum: Google [Bot] and 35 guests
