No sound on hosted server
Postby rickgood » Wed Mar 05, 2014 2:21 am
I was successfully using subsonic on my home computer but stepped up to the gigaport hosting option. My locally accessed files work fine but none of the songs will play on the hosted server. They appear to start but never do. It's on all players. The host company says everything is set up correctly so i'm coming here to seek answers. Any ideas?
rickgood
Re: No sound on hosted server
Postby spookybathtub » Wed Mar 05, 2014 3:00 am
Do you have ssh access to the server? What's in the log file?
spookybathtub
Postby rickgood » Wed Mar 05, 2014 3:11 am
Something like this:
[2014-03-04 23:59:24,738] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) /var/subsonic/transcode/lame: /lib/libc.so.6: version `GLIBC_2.7' not found (required by /var/subsonic/transcode/lame)
[2014-03-05 00:00:28,512] INFO PlaylistInputStream - admin listening to "FABULOUS 50s - 61/FATS DOMINO - BLUEBERRY HILL (DJ BINGO 35S CLIP).mp3"
[2014-03-05 00:00:28,515] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/lame] [-S] [-h] [--resample] [44.1] [-b] [128] [--tt] [BLUEBERRY HILL (DJ BINGO 35S CLIP)] [--ta] [FATS DOMINO] [--tl] [FABULOUS 50s] [/var/music/FABULOUS 50s - 61/FATS DOMINO - BLUEBERRY HILL (DJ BINGO 35S CLIP).mp3] [-]
[2014-03-05 00:02:51,179] INFO PlaylistInputStream - admin listening to "FABULOUS 50s - 61/FRANKIE LYMON & THE TEENAGERS - WHY DO FOOLS FALL IN LOVE (DJ BINGO 35S CLIP).mp3"
[2014-03-05 00:02:51,182] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/lame] [-S] [-h] [--resample] [44.1] [-b] [128] [--tt] [WHY DO FOOLS FALL IN LOVE (DJ BINGO 35S CLIP)] [--ta] [FRANKIE LYMON & THE TEENAGERS] [--tl] [FABULOUS 50s] [/var/music/FABULOUS 50s - 61/FRANKIE LYMON & THE TEENAGERS - WHY DO FOOLS FALL IN LOVE (DJ BINGO 35S CLIP).mp3] [-]
[2014-03-05 00:02:51,234] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/lame) /var/subsonic/transcode/lame: /lib/libc.so.6: version `GLIBC_2.7' not found (required by /var/subsonic/transcode/lame)
[2014-03-05 00:07:32,852] INFO PlaylistInputStream - admin listening to "FABULOUS 50s - 61/FATS DOMINO - BLUEBERRY HILL (DJ BINGO 35S CLIP).mp3"
[2014-03-05 00:07:32,855] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/lame] [-S] [-h] [--resample
rickgood
Postby rickgood » Wed Mar 05, 2014 3:27 pm
I have decided to just use the home server version.
rickgood
Postby spookybathtub » Wed Mar 05, 2014 7:26 pm
Apparently lame has a missing dependency. If you're interested in fixing it, try running lame on the command line by itself and see if you get the same error. If so, try reinstalling lame.
Also, I'm curious why you're using lame instead of the default ffmpeg transcoder.
spookybathtub
Postby rickgood » Thu Mar 06, 2014 4:12 am
I'm new to all this - I assume it was the default as it is the only choice in my player settings. If the lame is deleted will the system automatically use the default ffmpeg transcoder?
rickgood
Postby spookybathtub » Fri Mar 07, 2014 3:22 pm
I believe it would try to play everything natively in that case. Probably not a good idea.
Check your Transcoder settings, do they match the recommendations? http://www.subsonic.org/pages/transcoding.jsp
spookybathtub
Users browsing this forum: Google [Bot] and 29 guests
