Can't access subsonic after upgrading to 5.0 on Ubuntu serve
Postby jbannow » Fri Sep 26, 2014 6:06 pm
Problem Description: Can't access subsonic after upgrading to 5.0 on Ubuntu server
Troubleshooting Steps: restarted service, uninstalled and reinstalled subsonic
Playback Application and version: Chrome on Windows 7
Subsonic Version: Just upgraded to 5.0, can't provide more since web interface is down
Server Version: Just upgraded to 5.0, can't provide more since web interface is down
Hardware Platform: Ubuntu 12.04 LTS
Java Memory Limit: Dunno
Problem Filename: N/A
Output from ffmpeg -i: ffmpeg version 0.8.16-4:0.8.16-0ubuntu0.12.04.1, Copyright (c) 2000-2014 the Libav developers built on Sep 16 2014 18:33:49 with gcc 4.6.3
Last ten log file lines:
[2014-09-26 14:01:37,929] INFO DaoHelper - Checking database schema.
[2014-09-26 14:01:42,531] INFO DaoHelper - Done checking database schema.
[2014-09-26 14:01:43,289] INFO VersionService - Resolved local Subsonic version to: 5.0
[2014-09-26 14:01:46,098] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Sat Sep 27 03:00:00 EDT 2014
[2014-09-26 14:01:46,358] INFO UPnPService - Starting UPnP service...
[2014-09-26 14:01:46,633] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Fri Sep 26 14:06:46 EDT 2014
[2014-09-26 14:01:49,083] INFO UPnPService - Enabling UPnP/DLNA media server
[2014-09-26 14:01:49,084] INFO UPnPService - Starting UPnP service - Done!
[2014-09-26 14:01:56,406] WARN NetworkService - No UPnP router found.
jbannow
Re: Can't access subsonic after upgrading to 5.0 on Ubuntu s
Postby saphyrre » Tue Oct 07, 2014 4:55 pm
What port are you using? Did you check to see if the process is running, and if there is a java process listening on that port? Do you have iptables or ufw (default ubuntu firewall) enabled?
Assuming the port is 1234, try these commands:
lsof -i tcp:1234 | grep LISTEN
netstat -tunlap|grep java | grep LISTEN
Next step is to check the connection to that port via telnet from your local machine and the client machine. Also, if you use tomcat there are additional logs in tomcat/logs/ that you might want to check.
saphyrre
Users browsing this forum: Google [Bot] and 40 guests
