Can't connect outside of internal network
Postby ck100 » Mon Nov 03, 2014 3:37 am
I can't seem to connect outside of my internal network. This started with version 5.0 upgrade. I am running Windows 7 64-bit and Java version 7 build 71. I am the only user setup in Windows and I do not have a password. I have completed the following and still can't connect with my outside IP:
- Checked for port conflicts (tried different ports)
- Auto port forwarding (Subsonic settings) and manual port forwarding on router
- Turning off Window Firewall
- Starting / restarting service and multiple reboots after all of the above
Does anyone have something else I can check?
Joe
ck100
Re: Can't connect outside of internal network
Postby ck100 » Fri Nov 07, 2014 2:26 pm
Other ideas?
ck100
Users browsing this forum: Google [Bot] and 41 guests
