No Music is imported
Postby jeremyjjbrown » Thu Nov 20, 2014 3:23 am
Subsonic 5.0 is not importing any music.
I'm adding a directory path on my home server to the Subsonic Media Folder field, saving and hitting Scan media folders now. The contents of the folder are chmod'd a+r.
ll /drives/drive1/Music/ | tail -n 10
drwxrwxr-- 2 jeremy jeremy 4096 May 10 2013 What's Up Matador_ (Disc 1)#4FFA/
drwxrwxr-- 4 jeremy jeremy 4096 May 10 2013 Wilco/
drwxrwxr-- 3 jeremy jeremy 4096 Jul 9 2012 Will Stratton/
drwxrwxr-- 2 jeremy jeremy 4096 Jul 8 2012 Winterland 11_11_73 Set I/
drwxrwxr-- 2 jeremy jeremy 4096 Jul 8 2012 Winterland 11_11_73 Set II/
drwxrwxr-- 2 jeremy jeremy 4096 Jul 8 2012 Winterland Arena 02_24_74 I/
drwxrwxr-- 2 jeremy jeremy 4096 Jul 8 2012 Winterland Arena 02_24_74 II/
drwxrwxr-- 4 jeremy jeremy 4096 May 10 2013 Yeah Yeah Yeahs/
drwxrwxr-- 3 jeremy jeremy 4096 Jul 9 2012 YES/
drwxrwxr-- 4 jeremy jeremy 4096 May 10 2013 Yo La Tengo/
I get this in the log.
2014-11-19 21:13:52,801] INFO MediaScannerService - Starting to scan media library.
[2014-11-19 21:13:52,832] INFO MediaScannerService - Scanned media library with 1 entries.
[2014-11-19 21:13:52,832] INFO MediaScannerService - Marking non-present files.
[2014-11-19 21:13:52,834] INFO MediaScannerService - Marking non-present artists.
[2014-11-19 21:13:52,835] INFO MediaScannerService - Marking non-present albums.
[2014-11-19 21:13:52,838] INFO MediaScannerService - Completed media library scan.
[2014-11-19 21:13:52,853] INFO PlaylistService - Starting playlist import.
[2014-11-19 21:13:52,853] INFO PlaylistService - Completed playlist import.
[2014-11-19 21:13:52,853] INFO PlaylistService - Starting playlist statistics update.
[2014-11-19 21:13:52,856] INFO PlaylistService - Completed playlist statistics update.
Not sure what to do to import music.
jeremyjjbrown
Re: No Music is imported
Postby bobzmuda » Thu Nov 20, 2014 3:52 am
Having the same problem. The problem arose immediately after installing Subsonic 5.0 from version 4.x (I can't recall) on OSX Mavericks 10.9.5.
My issue arises from a USB connected hard drive. In version 4.x, my MP3 folder on the external hard drive was found by Subsonic and had no issues adding its files to the library. In 5.0, however, Subsonic still finds my MP3 folder on the external hard drive, but no longer pulls in the files to the library.
I've tested this by adding MP3 on a local disk without error.
*****RESOLVED*****
I resolved my issue by re-naming my MP3 folder on my external drive, and then updating the Subsonic settings to match the re-named MP3 folder. Perhaps it was a database conflict issue converting from 4.x to 5.0, even though I selected "clean-up database"
bobzmuda
Postby jeremyjjbrown » Thu Nov 20, 2014 2:35 pm
Mine is a fresh install on ubuntu 14.04 with an ext4 drive mounted the traditional manner via fstab. It may be worth noting that I am also sharing this drive via cifs, but Subsonic is accessing via absolute path.
Is it possible to download a 4.x version?
jeremyjjbrown
