Lost to ability to connect after installing 5.1
Postby ragepsv » Mon Feb 02, 2015 3:16 pm
I upgraded to 5.1 today and now I cannot connect to my server remotely. It pulls up fine locally. I assumed all the existing setting would be preserved, correct? Does anyone know if re-installing 5.0 may correct this problem? Thank you for any assistance with this.
Chris
ragepsv
Re: Lost to ability to connect after installing 5.1
Postby blueturtles » Mon Feb 02, 2015 3:43 pm
I had to adjust my firewall settings within Windows for subsonic 5.1 to work for me. Maybe try that?
blueturtles
Postby ragepsv » Mon Feb 02, 2015 4:43 pm
blueturtles wrote:I had to adjust my firewall settings within Windows for subsonic 5.1 to work for me. Maybe try that?
I run my server on an old XP machine that I don't use for anything else and the only way I can get it to work now is to disable the firewall completely. Not sure why this is the case.
ragepsv
Postby dpierce62 » Wed Feb 25, 2015 7:05 pm
Bump, ran into this same prob on my Subsonic Server (WinXP). After banging my head, getting grumpier (tunes only available on server :evil: ), and ready to depart Subsonic; I decided to read the forums........ :roll:
Thanks for bringing back calm to masses here....... :D
BTW, I only put in a exception for the Subsonic server and port (4040).
dpierce62
