Can't connect remotely
Postby JazzCollector » Sun Feb 08, 2015 2:18 pm
Greetings,
I am a new user having recently found Subsonic. I set it up on my home PC running Windows and let it automatically configure the router for port forwarding and it says that it was successful. I installed the Subsonic Android application on my phone and tablet and both work just fine as long as I am in my home connected to the same router. If I am at work or on my phone remotely, it cannot connect. In other words, if I go to my-chosen-sub-domain.subsonic.org (or the actual IP address), it just sits there and fails to connect, but at home and connected to the same router it works like a champ.
I realize that I am not providing information on my router, etc., and if that is necessary, I can do that. I am not using any other software or port-forwarding settings that would conflict, etc. I am a Fairpoint customer in New England and my router is whatever they hand out when they install DSL service.
I love this software and I want to be able to listen to music at work from my home computer.
Thanks for any help.
JazzCollector
Re: Can't connect remotely
Postby mitrailer » Mon Feb 09, 2015 4:34 pm
Find your router in this list (http://portforward.com/english/applications/port_forwarding/Subsonic/) and follow the walk-trough to open the ports subsonic needs
mitrailer
Postby kazrim » Fri Feb 20, 2015 4:50 pm
I am also new to all of this and also having major problems getting to connect remotely despite following every advice I can find. Connecting whilst on the home network is fine but cannot log in from anywhere else. I have tried to change the port forwarding settings closely following the above link as suggested but I get the following message on my bt hh5 when I add the new game/application and apply:
Conflict
The game or application you’ve selected conflicts with an application () you’ve already assigned to another device.
Please remove the other application or select the same device.
I also get the message on the subsonic app on my android phone that wrong user/password when I try and connect from anywhere but home.
Please can someone help. Any help will be gratefully received
kazrim
