JWPlayer Streaming - Updated
Postby bmalone667 » Mon Feb 23, 2015 6:42 am
Problem Description: After I upgraded my Subsonic to 5 JWPlayer seems to default to a 2000 Kbps. If I leave it at that then the media buffers every few seconds. If I change it down to 400 or so it works fine. Is there a place to change this "default" setting?
Troubleshooting Steps: I have gone into the server looking at the jw-player-5.10.swf file looking for the defaults and I can't find them.
Playback Application and version: JWPlayer
Subsonic Version: 5.1 (build 4340) – January 26, 2015
Server Version: jetty-6.1.x, java 1.7.0_71, Linux (91.0 MB / 198.0 MB)
Hardware Platform: CentOS 6.6
Output from ffmpeg -i:
FFmpeg version 0.6.5, Copyright (c) 2000-2010 the FFmpeg developers
  built on Jan 29 2012 17:52:15 with gcc 4.4.5 20110214 (Red Hat 4.4.5-6)
  configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --mandir=/usr/share/man --incdir=/usr/include --disable-avisynth --extra-cflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -fPIC' --enable-avfilter --enable-avfilter-lavf --enable-libdc1394 --enable-libdirac --enable-libfaac --enable-libfaad --enable-libfaadbin --enable-libgsm --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libx264 --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-shared --enable-swscale --enable-vdpau --enable-version3 --enable-x11grab
  libavutil     50.15. 1 / 50.15. 1
  libavcodec    52.72. 2 / 52.72. 2
  libavformat   52.64. 2 / 52.64. 2
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.19. 0 /  1.19. 0
  libswscale     0.11. 0 /  0.11. 0
  libpostproc   51. 2. 0 / 51. 2. 0
Last ten log file lines:
[2/23/15 3:02:41 AM CST]   INFO   MediaScannerService   Marking non-present albums.
[2/23/15 3:02:41 AM CST]   INFO   MediaScannerService   Completed media library scan.
[2/23/15 3:02:42 AM CST]   INFO   PlaylistService   Starting playlist import.
[2/23/15 3:02:42 AM CST]   INFO   PlaylistService   Completed playlist import.
[2/23/15 3:13:52 AM CST]   WARN   NetworkService   No UPnP router found.
[2/23/15 4:13:52 AM CST]   WARN   NetworkService   No UPnP router found.
[2/23/15 5:13:52 AM CST]   WARN   NetworkService   No UPnP router found.
[2/23/15 6:13:52 AM CST]   WARN   NetworkService   No UPnP router found.
[2/23/15 7:13:52 AM CST]   WARN   NetworkService   No UPnP router found.
[2/23/15 8:13:52 AM CST]   WARN   NetworkService   No UPnP router found.
bmalone667
Re: JWPlayer Streaming - Updated
Postby bmalone667 » Thu Mar 19, 2015 3:09 pm
No one has any advice?
bmalone667
Postby dstauth » Tue Apr 21, 2015 6:35 pm
I would also be interested in this. Not that it is hard to set it to 400 each time, but it would be nice if I could modify some code or if it was a setting.
dstauth
Users browsing this forum: No registered users and 143 guests
