Subsonic User Interface Extremely Laggy
Postby elemenopy » Wed Mar 04, 2015 3:55 pm
Relevant details about my system are below from the 'How to ask a question' sticky.
Problem Description: I have about 70,000 unique artists in my system now roughly and when I login to the user interface of Subsonic it is attempting to load all 70,000 clickable links on the left hand side of the screen. Is there anyway to turn off this feature or at least make it only pull the first like 100? This is causing quite an issue.
Troubleshooting Steps: I have no steps to resolve this issue. The UI is doing something that I can't control or that I do not know how to control.
Playback Application and Version: I am using the default web player that is embedded into the webpage.
Subsonic Version: 5.1 (build 4340) – January 26, 2015
Server Version: jetty-6.1.x, java 1.7.0_75, Linux (74.5 MB / 149.5 MB)
Hardware Platform: Linux CentOS 6.4 (Minimal)
Java Memory Limit: N/A (Linux)
Problem Filename: I do not have an issue with any file names or playing files.
Output from ffmpeg: The issue is not playing files. That is fine.
Last 10 Log File Lines: 3/4/15 9:42:17 AM CST] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Thu Mar 05 00:00:00 CST 2015
[3/4/15 9:42:17 AM CST] INFO UPnPService Starting UPnP service...
[3/4/15 9:42:18 AM CST] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Wed Mar 04 09:47:18 CST 2015
[3/4/15 9:42:18 AM CST] INFO UPnPService Disabling UPnP/DLNA media server
[3/4/15 9:42:18 AM CST] INFO UPnPService Starting UPnP service - Done!
[3/4/15 9:42:26 AM CST] INFO SonosService No Sonos controller found
[3/4/15 9:42:27 AM CST] WARN NetworkService No UPnP router found.
[3/4/15 9:42:42 AM CST] INFO VersionService Resolved latest Subsonic final version to: 5.2
[3/4/15 9:42:42 AM CST] INFO VersionService Resolved latest Subsonic beta version to: 5.2.beta1
[3/4/15 9:47:18 AM CST] INFO PodcastService Starting scheduled Podcast refresh.
[3/4/15 9:47:18 AM CST] INFO PodcastService Completed scheduled Podcast refresh.
elemenopy
Re: Subsonic User Interface Extremely Laggy
Postby elemenopy » Wed Mar 04, 2015 7:40 pm
Anybody have any solution for this? I'm willing to try experimental stuff if need be.
elemenopy
Postby mitrailer » Wed Mar 04, 2015 10:44 pm
-Delete the cache of your browser
-Or try another browser
mitrailer
Postby elemenopy » Wed Mar 04, 2015 11:30 pm
mitrailer wrote:-Delete the cache of your browser
The issue is that every time you login to the site even after clearing the browser, the left hand side of the screen ("Where it shows all your artists") contains 70,000 clickable links. I can't change this based on my browser though. I'm thinking this will take a code change on the server subsonic software or there may be some setting I'm not aware of to turn off this feature on subsonic?
elemenopy
Users browsing this forum: Google [Bot] and 28 guests
