HTTP ERROR: 503
HTTP ERROR: 503
Postby tornadotj » Fri Mar 06, 2015 6:59 pm
Hey all, I did a search but could not find anything specific to the exact problem I am having. This was working fine yesterday, but today it is broken. Whether on the localhost or on another computer on the network, when I try to go to http://ipaddress:4040, I get the following error.
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
I am running on Windows 7, using the latest version of Subsonic.
I've tried IE 10 and Google Chrome
I have uninstalled and reinstalled, and no luck. I even tried installing to a different drive.
Java reports Version 8 Update 40.
I've rebooted of course, with no luck.
Last few lines of service log:
6771 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
6802 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
7894 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
7956 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[192.168.1.9:9412](local),objID:[0:0:0, 0]]]]
The entire agent log:
3 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@6e1b77: display name [org.springframework.context.support.ClassPathXmlApplicationContext@6e1b77]; startup date [Fri Mar 06 06:46:34 CST 2015]; root of context hierarchy
234 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-agent.xml]
1061 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@6e1b77]: org.springframework.beans.factory.support.DefaultListableBeanFactory@8806ef
1155 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@8806ef: defining beans [service,agent,frame,settingsPanel,statusPanel]; root of factory hierarchy
Help please! I'm stumped!
Oh, and is there a way to change the service port?
tornadotj
Re: HTTP ERROR: 503
Postby borge689 » Fri Mar 06, 2015 9:27 pm
I just ran into this exact same issue on Arch after updating. I can't figure out how to fix it. Did you ever figure it out?
borge689
Re: HTTP ERROR: 503
Postby tornadotj » Fri Mar 06, 2015 9:37 pm
No, it just started today. I was on an older Java (don't know what) and upgraded today after the error started, so I don't think it was Java. Like I said, it was just working a day or two ago, I don't know what happened.
tornadotj
Re: HTTP ERROR: 503
Postby borge689 » Fri Mar 06, 2015 10:00 pm
What OS are you on? I suppose my Java was updated as well when I updated everything.
borge689
Re: HTTP ERROR: 503
Postby tornadotj » Fri Mar 06, 2015 10:26 pm
I posted my details in the original post. Windows 7. Note it was not working before I updated Java also. It was broken with no changes to the machine.
tornadotj
Re: HTTP ERROR: 503
Postby borge689 » Sat Mar 07, 2015 4:54 am
Ah, I even read that. I completely forgot. I've reinstalled twice with nothing. So far I've gotten to the point where subsonic starts as a process, and seems to work, but nothing comes up when I try to visit http://localhost:4040 or 8443.
Edit:
It's also worth noting that both ports appear to be closed. I'm not sure how to fix this.
borge689
Re: HTTP ERROR: 503
Postby tornadotj » Sun Mar 08, 2015 5:40 pm
It looks like we are the only two in the world with this issue. :(
tornadotj
Re: HTTP ERROR: 503
Postby alphawave7 » Sun Mar 08, 2015 5:58 pm
tornadotj wrote:It looks like we are the only two in the world with this issue. :(
Nearly 500 posts on this forum with '503' in the search term says otherwise. Here's but one..
viewtopic.php?f=2&t=15202&p=66694&hilit=503#p66694
Re: HTTP ERROR: 503
Postby tornadotj » Sun Mar 08, 2015 7:04 pm
Thank you, I must have been too specific in my searches because I couldn't find it. This worked. Saving the subsonic.script file and putting it back didn't save my settings, but I don't have a complex setup, so it was easy to manually reconfigure.
tornadotj
Re: HTTP ERROR: 503
Postby alphawave7 » Sun Mar 08, 2015 8:47 pm
Excellent! Wonder why the script file save didn't work..I too don't have more than a few users, but I know some here have dozens or more. :o
Re: HTTP ERROR: 503
Postby borge689 » Sun Mar 08, 2015 9:41 pm
I'm glad it worked for you, Tornadotj! And thanks for the link, alphawave7. Alas, I tried the subsonic.script method before and it did not work for me, perhaps because I did it incorrectly.
For now, I guess I'm stuck with my new problem, which I will continue to search the forums about.
borge689
