m4a Apple purchased songs don't play
Postby fatcat46 » Wed Apr 15, 2015 2:11 pm
I am using Subsonic version 5.2.1 (build 4428) on new Raspberry PI2. I cannot play any m4a files.
How do I fix this.
Fatcat46
fatcat46
Re: m4a Apple purchased songs don't play
Postby fatcat46 » Fri Apr 17, 2015 8:41 pm
more info:
I use subsonic in my firefox browser to play music on a windows7 64bit machine to listen to my music and also Isub on my iphone 6+
Hardware is raspberry PI2
Version 5.2.1 (build 4428) – March 4, 2015
Server jetty-6.1.x, java 1.7.0_75, Linux (60.8 MB / 118.3
I don't know how to get the following info from the PI:
Java Memory Limit:
Problem Filename:
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
[4/17/15 4:34:01 PM EDT] INFO PlayQueueInputStream admin listening to "PTXmas (Deluxe Edition)/01 Angels We Have Heard on High 1.m4a"
[4/17/15 4:34:01 PM EDT] INFO TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/media/mynas/Music/Pentatonix/PTXmas (Deluxe Edition)/01 Angels We Have Heard on High 1.m4a] [-map] [0:0] [-b:a] [192k] [-v] [0] [-f] [mp3] [-]
[4/17/15 4:34:01 PM EDT] INFO InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) /var/subsonic/transcode/ffmpeg: 1: /var/subsonic/transcode/ffmpeg: Syntax error: "(" unexpected
fatcat46
Postby fatcat46 » Sun Apr 19, 2015 7:20 pm
Please, will someone help me with the issues I have posted?
Thank you
fatcat46
Postby gogogo » Wed Sep 16, 2015 8:58 am
hello the ffmpeg is not working!
you need to install ffmpeg from repository e create a link to the subsonic ffmpeg folder,
follow this steps in your raspberry:
cd /var/subsonic/transcode/
tar -pczf transcode_backup.zip transcode
sudo rm /var/subsonic/transcode/ffmpeg
sudo apt-get install ffmpeg
sudo ln -s /usr/bin/ffmpeg /var/subsonic/transcode/ffmpeg
update subsonic webpage (f5) and now it will just works! :D
gogogo
Postby gogogo » Wed Sep 16, 2015 9:07 am
to use a multitrhead cpu working set transcoding to:
mp3: ffmpeg -i %s -map 0:0 -b:a %bk -v 0 -f mp3 -threads 4 -
flv: ffmpeg -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -vcodec libx264 -preset superfast -threads 4 -
mkv: ffmpeg -ss %o -i %s -c:v libx264 -preset superfast -b:v %bk -c:a libvorbis -f matroska -threads 4 -
gogogo
Users browsing this forum: Google [Bot] and 39 guests
