503 Error, DB connection issue
Postby grumpwagon » Fri May 01, 2015 3:59 pm
My best guess as to why this happened is a podcast tried to download, but encountered an error halfway through downloading. I can't remember the exact error text from subsonic, but it was the unexpected end of content error. That happens often enough with no problems. The issue was, I overwrote the partial file with a full copy of the file (just using the filesystem). Turned out that was a bad idea.
When navigating to subsonic on the web, I get a jetty error (HTTP ERROR: 503 SERVICE_UNAVAILABLE RequestURI=/ ). Subsonic.log shows the following stack trace.
[2015-05-01 10:48:06,506] INFO DaoHelper - Checking database schema.
[2015-05-01 10:48:07,248] ERROR DaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: error in script file line: 4762 java.io.IOException: org.hsqldb.HsqlException: Value too long
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:382)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:429)
at net.sourceforge.subsonic.dao.schema.Schema25.execute(Schema25.java:38)
at net.sourceforge.subsonic.dao.DaoHelper.checkDatabase(DaoHelper.java:122)
at net.sourceforge.subsonic.dao.DaoHelper.<init>(DaoHelper.java:75)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:135)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
Caused by: java.sql.SQLException: error in script file line: 4762 java.io.IOException: org.hsqldb.HsqlException: Value too long
at java.sql.DriverManager.getConnection(DriverManager.java:571)
at java.sql.DriverManager.getConnection(DriverManager.java:187)
... 76 more
[2015-05-01 10:48:07,327] INFO VersionService - Resolved local Subsonic version to: 5.2.1
I can't access http://<mysubsonic>/db.view . Is there a way I can edit the db and remove the entry of that podcast? Is that a bad idea?
grumpwagon
Re: 503 Error, DB connection issue
Postby grumpwagon » Mon May 04, 2015 4:01 pm
I've narrowed down what line is causing the issue in the subsonic.script file. Is that file ran every time subsonic starts up to establish the db? Or is that just a backup of sorts?
grumpwagon
Postby dbutts » Tue May 05, 2015 9:53 pm
I have similar, but not identical error
[2015-05-05 12:52:04,768] INFO DaoHelper - Checking database schema.
[2015-05-05 12:52:05,392] ERROR DaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: java.io.IOException: org.hsqldb.HsqlException: Unexpected token:
I did get a batch of windows updates last night (Win7 x32). That's all I know of that's changed on my pc.
Any thoughts?
dbutts
Postby dbutts » Wed May 06, 2015 12:17 pm
OK. I fixed mine by doing this:
stopped service
deleted \subsonic\db folder (or rename it)
start service
this of course required me to set it all up again but that didn't take long. You could probably back up users and other items first.
dbutts
Postby grumpwagon » Thu May 07, 2015 12:44 pm
Yeah, I tried backing up my DB then deleting it, but jetty was fucked up enough that that didn't work either.
grumpwagon
Postby envoy510 » Sun Dec 13, 2015 6:42 pm
dbutts wrote:OK. I fixed mine by doing this:
stopped service
start service
I have a ton of podcasts and other stuff. Setting it up all again... man, that's gonna take a while.
This jetty db corruption issue has me very bummed, and possibly looking for other solutions to my music needs. I can't be doing this setup every time I need to reboot my server.
envoy510
Postby envoy510 » Sun Dec 13, 2015 7:07 pm
See more discussion here:
viewtopic.php?f=2&t=15786
envoy510
