Best Realtime Search api implementation
Postby a7medo778 » Mon Jul 20, 2015 11:39 pm
hi there
i am building my own app based on subsonic's API's (ampache implementation) i am wondering whats the best way to implement realtime search ?
my catalog is pretty big (35k tracks) so thats kinda crucial, even if local cache/storage to be used thats fine
1 more question, is there any way to implement replayGain/normalize using the api's ? it would be wonderful if all tracks had the same sound level
thanks in advanced
regards
ahmad
note: i am using ionic for the app's, any additional tips are welcomed :D
a7medo778
Re: Best Realtime Search api implementation
Postby a7medo778 » Mon Jul 20, 2015 11:59 pm
1 general question, is there any recommendation engine/algorithm out there that analysis the listening patterns and data from my app and get resaults ?
all i am finding is based on either last.fm or spotify and since my tracks DNE on both of them they are kinda useless
a7medo778
