freenas setup
freenas setup
Postby rturner » Wed Feb 25, 2009 9:42 pm
I followed the instruction on the freenas setup for subsonic. I installed all the packages and java per the instruction guide. everything installed fine with no errors. i added in the startup script and ran the subsonic.sh and it told me to check the log. This is what the log says.
/libexec/ld-elf.so.1: Shared object "libthr.so.3" not found, required by "java"
any ideas on this??
rturner
Postby rturner » Fri Feb 27, 2009 1:35 am
so from what i have found the libthr.so.3 library doesnt work on 7. only 6. so in order to make this work you have to use an older version of freenas with bsd 6
rturner
same issue
Postby joeontherun » Thu Apr 30, 2009 3:12 am
I to am having this issue running subsonic damn so close as well,
Im running FreeBSD 6.4-RELEASE-p3 (revision 199506)
same error though /libexec/ld-elf.so.1: Shared object "libthr.so.3" not found, required by "java"
joeontherun
Postby sgx1 » Thu Apr 30, 2009 4:54 pm
I had the same issue when I used the wrong JRE.
This is the one I used:
Diablo Latte JRE 1.6.0-7 FreeBSD 6.x/i386 End-User 28M diablo-jre-freebsd6.i386.1.6.0.07.02.tbz
As of this week, I've been running SubSonic on my FreeNAS very successfully.
sgx1
cool
Postby joeontherun » Thu Apr 30, 2009 6:48 pm
Well i dont know if its my version but you have taken up a good point and i will try a difrent version tonight its a nightmare im at work vpning in to my home and having to upload the files through my mobile connection painfully slow,
im using diablo-jre-freebsd7.i386.1.6.0.07.02.tbz maby this is where im going wrong ill try your version ill let you know how things go,
I must say thanks for your information it may prove helpfull,
Im vpn,ing in to my home from work using my mobile connection im trying to us putty to fetch the java file but it doesent seem to want to download the whole thing just like 2k, think its becouse you need to tick an agrement thing in IE,
So i need to manualy upload the java file in to my freenas box :( not so good,
joeontherun
Working
Postby joeontherun » Thu Apr 30, 2009 7:16 pm
Well with the information you gave me my friend i managed to get it going in less than 2 mins thanks alot the version you said works perfect no error,
:lol:
joeontherun
Brilliant!
Postby joeontherun » Fri May 01, 2009 4:25 am
Iv been using this software all night its so adictive Thanks to the desighners amazing, i have so many albums and this just lays them out perfectly sends firefly server flying :o this should be built in to freenas not firefly,
joeontherun
Postby sgx1 » Fri May 01, 2009 10:34 pm
Glad that fixed the problem! You're right though, it's very addicting. It's great to be able to access my music from home while at work.
sgx1
