Can someone explain me the function of "Shortcuts"
Postby fraubi » Thu Mar 10, 2016 8:13 pm
under SETTUNGS --> GENERAL you can create "Shortcuts".
Can someone explain me the function and why would i need this......
Fraubi
fraubi
Re: Can someone explain me the function of "Shortcuts"
Postby daneren2005 » Thu Mar 10, 2016 9:37 pm
I'm curious about that too. I have never been able to figure out what they are for.
Postby toolman » Mon Mar 28, 2016 11:23 am
The Shortcut-function is a handy feature if you want some music folders to be easily accessable.
You can compare them with bookmarks in your browser.
All you have to do is type the foldername(s) in Settings > General > Shortcuts and soon the shortcut will appear at the top of the index-page.
So if you want the folder The Beatles to be a shortcut you just type in "The Beatles"
If you have multiple folders you want to be bookmarked in this way, you'll have to seperate them with a space between them like:
"The Beatles" Madonna Rock
toolman
Postby acroyear » Mon Mar 28, 2016 12:23 pm
I'm not seeing it change anything right now. I wonder if this is a bug/missing feature in the 6.0b2 index page and (restored) sidebar?
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Postby toolman » Mon Mar 28, 2016 4:48 pm
@ acroyear
I'm running SS 6 Beta2 and when I made a shortcut it showed up on the indexpage. Perhaps you'll have to do a folderscan to get it visible. It could be that it showed up in my setup because there was a folderscan going when i made my shortcut.
[EDIT]:
Just made a new shortcut in my setup and it appeared immediatly on my index page.
So there's no need to rescan your folders.
toolman
Postby acroyear » Mon Mar 28, 2016 5:02 pm
ok, when i added one that was a top-level folder, I saw it show up. Not much use to me, as my larger folders in my collection have subfolders within them. Since SubFire is my primary player, if I need to skip straight to an artist, I just use the Artist/Album browser instead of the music directory one.
Joe Shelby
acroyear
Postby toolman » Sat Apr 16, 2016 10:39 am
You can make shortcuts to subfolders, if you're doing it right.
Just made a shortcut:
"Led Zeppelin\Led Zeppelin III" Which shows up on my index-page as "Led Zeppelin III".
toolman
