HTTP ERROR: 503
HTTP ERROR: 503
Postby sandman121383 » Wed Apr 06, 2016 8:22 pm
hey guys!
getting "HTTP ERROR: 503"
i tried all recommendations here from searching. i tried the db backup trick.
i even went as far as uninstalling subsonic, and rebooting. now with a fresh install. still getting issue.
is it java? i can roll back to an older version if need be. can someone shed some light on this issue please?
sandman121383
Re: HTTP ERROR: 503
Postby sandman121383 » Fri Apr 08, 2016 2:20 am
anyone having this problem, after uninstalling i went into my c:\ drive and deleted files left over after uninstall...reboot and then fresh installation brought it back up but lost all users,playlists, etc.
hope this helps someone in the future since i found no answers searching myself
sandman121383
Re: HTTP ERROR: 503
Postby insann » Wed Apr 13, 2016 1:05 pm
Maybe some logs ?
can't help you more without more infos !
insann
Re: HTTP ERROR: 503
Postby jl55378008 » Wed Apr 13, 2016 2:54 pm
sandman121383 wrote:anyone having this problem, after uninstalling i went into my c:\ drive and deleted files left over after uninstall...reboot and then fresh installation brought it back up but lost all users,playlists, etc.
I'm having the same problem. Tried what you said and the same thing happened. Was able to pull the Subsonic page up, but it was like a fresh install. All previous data is gone.
I still have the backups, but when I try to put the backup files back in the db folder, it goes back to the 503 error.
jl55378008
Re: HTTP ERROR: 503
Postby insann » Sat Apr 16, 2016 9:09 pm
so you're Db is broken ... obsiously try to extract from it the settins that you need !
in the subsonic.script files are all the user settings .
Insann
insann
