Ubuntu 16.04 xenial, how to setup subsonic
Postby mrdrew » Fri Sep 02, 2016 9:56 pm
I recently upgraded to ubuntu 16.04. Subsonic server is now kaput!
I'm using UbuntuUpdates for the PPA http://www.ubuntuupdates.org/package/ge ... b/subsonic
(6.0-1~getdeb1)
Installed those package list from here http://www.ubuntuupdates.org/ppa/getdeb ... ist=xenial
drew@mimi:/var/subsonic$ sudo systemctl status subsonic.service
● subsonic.service - LSB: Subsonic daemon
   Loaded: loaded (/etc/init.d/subsonic; bad; vendor preset: enabled)
   Active: active (exited) since Fri 2016-09-02 14:35:23 PDT; 17min ago
     Docs: man:systemd-sysv-generator(8)
  Process: 3231 ExecStop=/etc/init.d/subsonic stop (code=exited, status=0/SUCCESS)
  Process: 3235 ExecStart=/etc/init.d/subsonic start (code=exited, status=0/SUCCESS)
Sep 02 14:35:23 mimi systemd[1]: Starting LSB: Subsonic daemon...
Sep 02 14:35:23 mimi systemd[1]: Started LSB: Subsonic daemon.
Looks like it clearly has something to do with the error of /etc/init.d/subsonic, but I can't really find anything wrong in them. There haven't been any entries to any of the log files in /var/subsonic, they're all dated a few days ago.
sudo service subsonic restart
doesn't do anything
sudo systemctl start subsonic.service
doesn't do anything
there aren't any notes about 'subsonic' in the /var/log/messages either.
any ideas on where to start looking next? Thanks!
mrdrew
Re: Ubuntu 16.04 xenial, how to setup subsonic
Postby mrdrew » Fri Sep 02, 2016 10:04 pm
downloaded version 6.0.deb from Subsonic, and did a sudo dpkg -i subsonic.deb and that seems to have done the trick. Which I had that PPA going. Ah well.
mrdrew
Postby mrdrew » Wed Sep 07, 2016 1:32 pm
the package subsonic got added to the apt-get repositories. Now whenever I do an apt-get update, then upgrade, it tries to "upgrade" to the 6.0-1~getdeb1 version from the ubuntuupdates.org repository. I've put a hold on the package, and now the other dependencies are reporting as they're unneeded and should be auto-removed (flac, vorbis, etc.). Doh!
Any other suggestions on how to make this installation a little less janky?
mrdrew
Postby thebestnumberis42 » Wed Oct 19, 2016 10:06 pm
Any updates on this? I'm looking install Subsonic on Linux Mint 18 and hope to avoid these pitfalls.
Thanks mate.
thebestnumberis42
Postby mrdrew » Wed Oct 19, 2016 10:12 pm
Nothing new here. I did the install from the dpkg from subsonic.org download page. That one worked great, and is still working fine.
mrdrew
