Raspberry 3 - Raspbain jessi - DLNA will not showing off
Postby tehmilcho » Thu Sep 15, 2016 9:37 am
Hi there,
i switch my Subsonic from a Windows-System(on Windows everything works fine) to a Raspberry 3 with lasted version of "Raspbian Jessi lite". its a brand new installation, i just set the System up (Hostname, Static IP, Java) and installed subsonic.
Subsonic webinterface works fine but if i enable DLNA nothing happens, i cant see the DLNA-Server on my Clients (Windows 10, Mobile Apps, Xbox etc). i have my music on a Webdav network drive, is this a Problem
for the DLNA-Server? Is something missing? In the subsonic logs i cant found a Problem. Also on my Router UPNP is enabled and works with other devices like the Xbox but not with Subsonic on linux.
License   Subsonic Premium
Version   6.0 (build a7857c) – 30. April 2016
Server   jetty-6.1.x, java 1.8.0_65, Linux (52,0 MB / 55,7 MB)
etc\default\Subsonic
SUBSONIC_ARGS="--port=4040 --max-memory=800 --host=192.168.178.27"
Subsonic.log
[15.09.16 11:17:20 MESZ]   INFO   HsqlDaoHelper   Checking database schema.
[15.09.16 11:17:23 MESZ]   INFO   HsqlDaoHelper   Done checking database schema.
[15.09.16 11:17:24 MESZ]   INFO   SettingsService   Java: 1.8.0_65, OS: Linux
[15.09.16 11:17:24 MESZ]   INFO   VersionService   Resolved local Subsonic version to: 6.0
[15.09.16 11:17:26 MESZ]   INFO   MediaScannerService   Automatic media library scanning scheduled to run every 14 day(s), starting at Fri Sep 16 03:00:00 CEST 2016
[15.09.16 11:17:26 MESZ]   INFO   UPnPService   Starting UPnP service...
[15.09.16 11:17:26 MESZ]   INFO   PodcastService   Automatic Podcast update disabled.
[15.09.16 11:17:28 MESZ]   INFO   UPnPService   Enabling UPnP/DLNA media server
[15.09.16 11:17:28 MESZ]   INFO   UPnPService   Starting UPnP service - Done!
[15.09.16 11:17:36 MESZ]   WARN   NetworkService   Failed to create port forwarding.
[15.09.16 11:18:05 MESZ]   INFO   BootstrapVerificationFilter   Servlet container: jetty-6.1.x
[15.09.16 11:18:26 MESZ]   INFO   VersionService   Resolved latest Subsonic final version to: 6.0
[15.09.16 11:18:26 MESZ]   INFO   VersionService   Resolved latest Subsonic beta version to: 6.0.beta2
Subsonic_sh.log
[GC (Allocation Failure)  40565K->26129K(56988K), 0.0773719 secs]
[GC (Allocation Failure)  42129K->30627K(56988K), 0.1738698 secs]
80450 [btpool0-2] INFO org.directwebremoting.log.startup - Starting: Using container abstraction org.directwebremoting.server.servlet2.Servlet24ContainerAbstraction
80519 [btpool0-2] INFO org.directwebremoting.servlet.UrlProcessor - Probably not an issue: the url:/gi.js (org.directwebremoting.gi.GiHandler) Handler is not available. This is only an problem if you wanted to use it.
[GC (Allocation Failure)  46564K->33886K(56988K), 0.1071172 secs]
[GC (Allocation Failure)  49886K->35477K(56988K), 0.0734495 secs]
[GC (Allocation Failure)  51477K->35864K(56988K), 0.0316041 secs]
[GC (Allocation Failure)  51841K->37556K(56988K), 0.0367998 secs]
[GC (Allocation Failure)  53556K->36595K(56988K), 0.0256164 secs]
[GC (Allocation Failure)  52595K->36689K(56988K), 0.0233078 secs]
tehmilcho
Re: Raspberry 3 - Raspbain jessi - DLNA will not showing off
Postby tehmilcho » Thu Sep 15, 2016 4:53 pm
i reinstalled the Raspberry with Raspbain (Full, inlc Desktop) and installed Subsonic again. Now i can see the DLNA Server on my Windows Client. But if i try to use it over Windows Media Player, the Player says everytime "No files on Remote ....". But when i use the MS Explorer i can see the Files. In my test i added 15songs to the Local Harddrive of the Raspberry (to check if the Problem is the WebDav).
Anyone a idea how i can fix this?
tehmilcho
Postby tehmilcho » Sun Sep 18, 2016 5:06 pm
Okay.. i found out the Problem with the not Showing DLNA on Windows 10 wars IPV6, i disabled it on my Router. Now the DLNA-Server seens to showing all the time.
But i cant use the Subsonic DLNA, i installed also "MIniDLNA" both uses the Same Networkdrive, MiniDLNA workfine. But Subsonic shows the Files but i cant play it.
I think the Problem is the Folder Structure. So looks the folder on the DLNA-Clients
Subsonic DLNA Folder:
- Box -> the Music files (Box is the Name of my Mounting Point)
- Playlists
MIniDLNA Folder:
- Pictures
- Music -> the Musik files
- Folders
- Video
I think thats the reason why the Mediaplayer cant find files on the DLNA from Subsonic. Anyone can conform this?
tehmilcho
Users browsing this forum: No registered users and 60 guests
