[SOLVED] blank page on first login
Postby swfdh » Thu Nov 03, 2016 10:14 am
Hello everybody !
I need your help here as I am struggling with installation of subsonic :)
i googled for two days to get some advices on my problem but nothing helped me..
so here we are :
Problem Description: when I connect to localhost:4040 i get a blank webpage http://localhost:4040/login.view?
Troubleshooting Steps: changed the port to differents random ports a few times, uninstalled subsonic and openjdk a few times too, and tried openjdk from version 7 to 9
Playback Application and version: Standard Subsonic Web Interface. with subsonic for android, can connect to the server but no music shown as I couldn't do the first setup
Subsonic Version: can't acces to web interface, apt-get install subsonic give me 6.0-1
Server Version: can't connect to web interface
Hardware Platform: ubuntu 16.04 on a VPS
Java Memory Limit: (Windows: found in the Subsonic Agent in the taskbar)
Problem Filename: (If you are having difficulty with a particular file, please include it's name)
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
Last ten log file lines:
1501575 [btpool0-1] WARN org.mortbay.log - Nested in org.apache.jasper.JasperException: org.apache.jasper.JasperException: Unable to compile class for JSP
Generated servlet error:
The type java.lang.Object cannot be resolved. It is indirectly referenced from required .class files
   at org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:84)
   at org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:328)
   at org.apache.jasper.compiler.JDTCompiler.generateClass(JDTCompiler.java:409)
   at org.apache.jasper.compiler.Compiler.compile(Compiler.java:297)
   at org.apache.jasper.compiler.Compiler.compile(Compiler.java:276)
   at org.apache.jasper.compiler.Compiler.compile(Compiler.java:264)
   at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:563)
   at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:303)
   at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314)
   at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264)
   at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:362)
   at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:268)
   at org.mortbay.jetty.servlet.Dispatcher.error(Dispatcher.java:135)
   at org.mortbay.jetty.servlet.ErrorPageErrorHandler.handle(ErrorPageErrorHandler.java:101)
   at org.mortbay.jetty.Response.sendError(Response.java:272)
   at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:429)
[1642.788s][info][gc] GC(59) Pause Initial Mark (G1 Evacuation Pause) 52M->26M(64M) (1642.783s, 1642.788s) 5.018ms
[1642.788s][info][gc] GC(60) Concurrent Root Region Scan (1642.788s)
[1642.789s][info][gc] GC(60) Concurrent Root Region Scan (1642.788s, 1642.789s) 1.500ms
[1642.789s][info][gc] GC(60) Concurrent Mark (1642.789s)
[1642.828s][info][gc] GC(60) Concurrent Mark (1642.789s, 1642.828s) 38.834ms
[1642.837s][info][gc] GC(60) Pause Remark 27M->27M(64M) (1642.828s, 1642.837s) 8.565ms
[1642.837s][info][gc] GC(60) Pause Cleanup 27M->27M(64M) (1642.837s, 1642.837s) 0.158ms
[1792.688s][info][gc] GC(61) Pause Young (G1 Evacuation Pause) 52M->26M(64M) (1792.685s, 1792.688s) 2.473ms
[1912.886s][info][gc] GC(62) Pause Initial Mark (G1 Evacuation Pause) 52M->26M(64M) (1912.882s, 1912.886s) 3.494ms
[1912.886s][info][gc] GC(63) Concurrent Root Region Scan (1912.886s)
[1912.887s][info][gc] GC(63) Concurrent Root Region Scan (1912.886s, 1912.887s) 1.392ms
[1912.887s][info][gc] GC(63) Concurrent Mark (1912.887s)
[1912.929s][info][gc] GC(63) Concurrent Mark (1912.887s, 1912.929s) 41.860ms
[1912.939s][info][gc] GC(63) Pause Remark 28M->28M(64M) (1912.929s, 1912.939s) 9.738ms
[1912.939s][info][gc] GC(63) Pause Cleanup 28M->28M(64M) (1912.939s, 1912.939s) 0.131ms
I think there is a problem with my java installation but cannot find how to repare it (linux mid-newbie here ! )
have a nice day !
'edit : [SOLVED]'
swfdh
Re: blank page on first login
Postby toolman » Thu Nov 03, 2016 10:24 am
Perhaps you need to install Java from Oracle for Subsonic to work properly.
http://www.wikihow.com/Install-Oracle-J ... untu-Linux
toolman
Postby swfdh » Thu Nov 03, 2016 11:16 am
hell yeah !
thought the version of openjdk from apt-get would work, but your version is the one :D
thank you very much, i can now configure my subsonic
have a great day !
swfdh
Re: [SOLVED] blank page on first login
Postby toolman » Thu Nov 03, 2016 12:32 pm
Thanks for letting us know that you've solved the problem.
A great day to you too.
toolman
