DNS Resolution Issue
Postby john.laguardia » Sat Jan 14, 2017 11:08 pm
I am having issues accessing my subsonic server from outside of my network. Port forwarding and subsonic domain in settings, network look good. They have been verified as successful from within Subsonic. I also used the open port check tool online and It was able to see me at
It seems like my URL popster.subsonic.org is not resolving correctly because it is resolving to 52.51.15.224. When I check it in the network utility, I get the following which verifies this:
Lookup has started…
Trying "popster.subsonic.org"
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 36408
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;popster.subsonic.org. IN ANY
;; ANSWER SECTION:
popster.subsonic.org. 1800 IN A 52.51.15.224
Received 54 bytes from 75.75.75.75#53 in 78 ms
How do I get subsonic MX records to see me at the correct public IP of ??
Thank you!
Last edited by john.laguardia on Tue Jan 17, 2017 7:54 pm, edited 1 time in total.
john.laguardia
Re: DNS Resolution Issue
Postby LRanger » Sun Jan 15, 2017 12:57 am
Seems to be accessible here.
LRanger
Postby john.laguardia » Sun Jan 15, 2017 1:25 am
Wow. Thanks for verifying that. I will do some additional testing outside of my network. Thank you.
john.laguardia
Postby toolman » Mon Jan 16, 2017 2:41 pm
The address that the paid version of subsonic grants you is a domain redirection and not a domain registration. So there's no MX records.
Whenever you try to resolve your subsonic.org adress it will always come up with the ip-adress 52.51.15.224.
But the redirection is working cause I too can connect to your server just using the popster.subsonic.org adress.
toolman
Postby john.laguardia » Tue Jan 17, 2017 7:53 pm
Roger that. I appreciate the help. Thank you!
john.laguardia
Postby utopian » Tue Jan 17, 2017 8:28 pm
I can connect to it as well :)
utopian
Users browsing this forum: Bing [Bot] and 29 guests
