FLAC playback stops anywhere between 5-60 sec
Postby DeathCon » Sun Jan 15, 2017 1:51 pm
Hi.
I've been trying to get subsonic to playback FLAC files with replaygain.
After some fiddling with the transcoder settings I was finally able to get subsonic to transcode FLAC files with replaygain to mp3 using the following settings:
Step 1: sox %s −−replay−gain album -p Step 2: ffmpeg -i - -map 0:0 -b:a %bk -v 0 -f mp3 -
Now if I remove step 2 from the chain, an external player (tomahawk in this case) will start to play the file, but stop anywhere between 5-60 sec depending on the bitrate. The log will then contain a bunch of info I'm unable to decipher anything from.
Any insight into what is causing this error would be greatly appreciated!
The following is the log info from a playback attempt:
[2017-01-15 14:43:41,776] WARN RESTFilter - Error in REST API: EofException
org.mortbay.jetty.EofException
   at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:760)
   at org.mortbay.jetty.AbstractGenerator$Output.blockForOutput(AbstractGenerator.java:546)
   at org.mortbay.jetty.AbstractGenerator$Output.flush(AbstractGenerator.java:567)
   at org.mortbay.jetty.HttpConnection$Output.flush(HttpConnection.java:907)
   at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:628)
   at org.mortbay.jetty.AbstractGenerator$Output.write(AbstractGenerator.java:575)
   at net.sourceforge.subsonic.controller.StreamController.handleRequest(StreamController.java:256)
   at net.sourceforge.subsonic.controller.RESTController.stream(RESTController.java:1544)
   at sun.reflect.GeneratedMethodAccessor68.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Unknown Source)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
   at org.mortbay.servlet.UserAgentFilter.doFilter(UserAgentFilter.java:81)
   at org.mortbay.servlet.GzipFilter.doFilter(GzipFilter.java:148)
   at net.sourceforge.subsonic.security.RESTRequestParameterProcessingFilter.doFilter(RESTRequestParameterProcessingFilter.java:113)
   at net.sourceforge.subsonic.filter.RESTFilter.doFilter(RESTFilter.java:60)
   at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:59)
   at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:205)
Caused by: java.io.IOException: An existing connection was forcibly closed by the remote host
   at sun.nio.ch.SocketDispatcher.write0(Native Method)
   at sun.nio.ch.SocketDispatcher.write(Unknown Source)
   at sun.nio.ch.IOUtil.writeFromNativeBuffer(Unknown Source)
   at sun.nio.ch.IOUtil.write(Unknown Source)
   at sun.nio.ch.SocketChannelImpl.write(Unknown Source)
   at org.mortbay.io.nio.ChannelEndPoint.flush(ChannelEndPoint.java:166)
   at org.mortbay.io.nio.SelectChannelEndPoint.flush(SelectChannelEndPoint.java:208)
   at org.mortbay.jetty.HttpGenerator.flush(HttpGenerator.java:693)
   ... 70 more
[2017-01-15 14:43:41,779] ERROR JAXBWriter - Failed to marshal JAXB
java.lang.IllegalStateException: STREAM
   at org.mortbay.jetty.Response.getWriter(Response.java:583)
   at net.sourceforge.subsonic.controller.JAXBWriter.writeResponse(JAXBWriter.java:140)
   at net.sourceforge.subsonic.controller.JAXBWriter.writeErrorResponse(JAXBWriter.java:154)
   at net.sourceforge.subsonic.filter.RESTFilter.handleException(RESTFilter.java:76)
   at net.sourceforge.subsonic.filter.RESTFilter.doFilter(RESTFilter.java:62)
[2017-01-15 14:43:41,779] ERROR RESTFilter - Failed to write error response.
[2017-01-15 14:43:41,983] INFO TranscodeInputStream - Starting transcoder: c:\subsonic\transcode\sox E:\Music\The Shins\2001 - Oh, Inverted World\01 - Caring Is Creepy.flac --replay-gain album -p
DeathCon
Re: FLAC playback stops anywhere between 5-60 sec
Postby Exrace » Sun Jan 15, 2017 2:08 pm
Being a windows installation have you checked file permissions?
Do you run subsonic service as system or a user?
Exrace
Postby DeathCon » Sun Jan 15, 2017 2:20 pm
Subsonic-service is run as system, while the agent is run as a user with admin privileges.
But I wouldn't think permissions would be a problem seeing as the transcode chain I posted successfully plays on the web player, while only using the first step in the chain starts playback on an external player, but then stops.
Thanks for the reply.
DeathCon
Postby Exrace » Sun Jan 15, 2017 2:46 pm
What version you running?
See if this thread helps.
https://sourceforge.net/p/subsonic/bugs/120/
I read some other posts reports that report the issue might be due to a timeout of the stream from the client you're using.
I use Tomahawk and have not run into this on my 6.0 beta 2 setup
Possibly realated to this report of transcoding settings.:
https://github.com/tsquillario/Jamstash/issues/108
Hope this helps.
Exrace
Postby DeathCon » Sun Jan 15, 2017 3:05 pm
I'm running the 6.0 version from April.
Thanks for the links, but I'm pretty sure the problem isn't the client.
I've tried multiple times in the past to get subsonic working with FLAC and replaygain with different clients, but I've always run into this problem.
The second link mentions transcodig FLAC to a lossy format, which I have no issues with. I rather think the problem is related to PCM playback.
DeathCon
