Highest Rated Albums causing Java exception error
Postby bluetooth » Tue Apr 21, 2009 9:14 pm
I recently re-arranged my albums from:
d:\music\wilco\[1996] Being There
to
d:\music\artists\wilco\[1996] Being There
I have recreated the index multiple times, but when I click on the highest rated albums, I get a java exception error that it cannot access:
which is where the album used to be.
Any idea where, or how I can clear out my highest rated albums?
Also, the most recently played setting returns a blank screen.
Any suggestions, other than reinstalling?
Thanks in advance
paid Subsonic user
bluetooth
Postby jigsaw » Tue Apr 21, 2009 10:07 pm
you could try clearing out the user ratings from the database
log in as admin and go to http://<your_host>/subsonic/db.view and run the command
select * from user_rating
If you see the paths which no longer exist you can clear it with this
delete from user_rating
If you know more about SQL you can also update all the paths, but that's a bit more complex SQL :)
jigsaw
Fantastic
Postby bluetooth » Wed Apr 22, 2009 1:14 am
That is great, thanks Jigsaw.
I have a couple of questions.
I need to clear out the 'Most Recently Played' and Most Often Played categories as well. Would you have those as well (please) ?
Also, doing a bit of research, would something like work?
1. select * from user_rating
2. replace('d:\music','d:\music\','d:\music\artists\')
I tried it, and I get an unexpected token error.
paid Subsonic user
bluetooth
Re: Fantastic
Postby jigsaw » Wed Apr 22, 2009 4:14 pm
bluetooth wrote:I need to clear out the 'Most Recently Played' and Most Often Played categories as well. Would you have those as well (please) ?
If I understood you correctly the Most Recently Played was blank? Which could indicate that you need to rebuild your index. I am suspecting that there may be a relation to the altered paths you've introduced.
bluetooth wrote:Also, doing a bit of research, would something like work?
Nah, that won't work. I don't know where you got the replace-command from, but that is not SQL. You would have to use substring and concat. I'm too tired to write it right now, but I have a better idea.
- Stop subsonic
- Find the SUBSONIC_HOME/db folder
- edit the file subsonic.script
-- here you should find all the input that will be re-entered into the database at startup. Just use your favorite text-editor to search-and-replace all instances of d:\music with d:\music\artist
- restart subsonic
jigsaw
