Cover download doesn't work (solution found)
Postby fault1er » Sat Jan 27, 2018 11:56 am
Hi everyone,
everytime I'm trying to download a cover in Subsonic i get the Error:
javax.net.ssl.SSLException: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
It worked for a short time after upgrading from subsonic 5.x to 6.1.3 - but at a moments notice it doesn't work anymore.
Does anyone have an idea what's wrong or have a workaround for this? I found out, it has something to to with https:// ... when i'm typing an url with http:// only it works like a charm...
Thanks in advance! :)
fault1er
Re: Cover download doesn't work
Postby acroyear » Sat Jan 27, 2018 7:37 pm
It seems like it is likely specific to that particular host and its SSL/HTTPS configuration and certificate. can you give an example of one of the URLs that's failing?
I've had no issues with most of the https sites I go to like Amazon, when last.fm is missing it or when i'm looking for an alternative.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Postby fault1er » Sun Jan 28, 2018 11:44 am
acroyear wrote:It seems like it is likely specific to that particular host and its SSL/HTTPS configuration and certificate. can you give an example of one of the URLs that's failing?
That's the point. It doesn't even work with pictures from last.fm.
Like this one: https://lastfm-img2.akamaized.net/i/u/3 ... 94806b.png
It seems like the server has problems with https reguests or something. I'm running subsonic on a windows server 2012 r2 standard if that's an important information.
I'm a little bit clueless about that and have no idea what to do. Nobody but me in this forum seems to have that problem... :?
fault1er
Postby acroyear » Sun Jan 28, 2018 5:03 pm
Maybe totally uninstall and reinstall Java? Might be that you have a corrupted keystore in your Java installation.
Joe Shelby
acroyear
Postby fault1er » Sun Jan 28, 2018 6:24 pm
Oh, I got it to work :)
The solution was to reduce the memory limit from 1500MB to 1024MB, but I have no idea how that can be related :roll:
Nevertheless many thanks acroyear!
fault1er
Re: Cover download doesn't work (solution found)
Postby zeroth » Sun Jul 22, 2018 1:19 pm
The correct solution is to reinstall Java. I too had issue downloading cover art with https:// links and many times the download would fail within subsonic. Everything is working perfectly now.
zeroth
Users browsing this forum: No registered users and 73 guests
