subsonic doesn't scan in new tracks
Postby briand095 » Sun Mar 08, 2020 1:26 am
I run subsonic in docker on a linux server. Today I added some new music and checked afterwards after the scan time and the music was not there. the only way I can get new music to show up is disable the folder, clean up database and re-enable folder and click scan media folders now. Other than that, the program works. Please ELI5 on what I need to do and fix, this is getting tiresome to do, thanks.
The log showing that scan was started, but no errors, but new music I uploaded isn't in the list.
[2020-03-08 00:00:00,592] INFO MediaScannerService - Starting to scan media library.
[2020-03-08 00:00:01,697] INFO MediaScannerService - Scanned media library with 250 entries.
[2020-03-08 00:00:01,893] INFO MediaScannerService - Scanned media library with 500 entries.
[2020-03-08 00:00:02,072] INFO MediaScannerService - Scanned media library with 750 entries.
[2020-03-08 00:00:02,241] INFO MediaScannerService - Scanned media library with 1000 entries.
[2020-03-08 00:00:02,419] INFO MediaScannerService - Scanned media library with 1250 entries.
[2020-03-08 00:00:02,604] INFO MediaScannerService - Scanned media library with 1500 entries.
[2020-03-08 00:00:03,185] INFO MediaScannerService - Scanned media library with 1750 entries.
[2020-03-08 00:00:03,394] INFO MediaScannerService - Scanned media library with 2000 entries.
[2020-03-08 00:00:04,028] INFO MediaScannerService - Scanned media library with 2224 entries.
[2020-03-08 00:00:04,028] INFO MediaScannerService - Marking non-present files.
[2020-03-08 00:00:04,030] INFO MediaScannerService - Marking non-present artists.
[2020-03-08 00:00:04,030] INFO MediaScannerService - Marking non-present albums.
[2020-03-08 00:00:04,031] INFO MediaScannerService - Completed media library scan.
[2020-03-08 00:00:04,091] INFO PlaylistService - Starting playlist import.
[2020-03-08 00:00:04,092] INFO PlaylistService - Completed playlist import.
briand095
Re: subsonic doesn't scan in new tracks
Postby 3Dscrewer » Mon Mar 09, 2020 10:26 am
That log says nothing, have a look at other log files in VAR/LOG or VAR/APACHE or similar if you are having something like that, may be there are more informations. I guess in 90% it's a rights problem in Linux and not a subsonic problem.
viewtopic.php?f=2&t=5506
3Dscrewer
