Problem with subsonic reverse apache
Postby plvallee » Mon Aug 29, 2022 4:28 am
I'm using Subsonic on unbuntu server 22.04 with apache2. I have read a lot of documentation on the internet for Subsonic to be reachable at http://myserver.com/subsonic by setting up a reverse server. Subsonic works perfectly when I access it from http://myserver.com:4040 or when I access via the reverse server that I would like to: http://myserver.com/subsonic subsonic seems to load in a way incomplete. No image, no player. see screenshot here: https://pedagogig.quebec/capture.jpg someone know how resolve this problem ?
plvallee
Re: Problem with subsonic reverse apache
Postby Exrace » Tue Aug 30, 2022 11:30 pm
You need to look at the broken links for clues, but my guess is the reverse proxy you setup is not rewriting the links correctly for the subdirectory you specified.
Exrace
