[Bug] Error saving cover image if path contains ampersand
Postby mgrant » Mon Jun 08, 2009 2:04 am
Some of the folders in my music collection contain an ampersand. Subsonic throws an exception when attempting to save cover images into such folders.
[6/8/09 1:59:12 AM GMT] INFO AmazonSearchService Found 1 cover image(s) at Amazon.com in 552 ms.
[6/8/09 1:59:21 AM GMT] WARN CoverArtService Failed to save cover art for /music/You, Me & Iowa/You, Me & Iowa
mgrant
Postby mixmaster » Mon Jun 08, 2009 3:59 pm
Hmmm, I cannot repro this. I was able to download & save cover art for "A Man & The Blues". But I'm on Windows, looks like you're using a *nix?
________
mixmaster
Postby jigsaw » Mon Jun 08, 2009 4:47 pm
Did a quick test on my Linux, but it works fine for me. I tested with both a comma and an ampersand. Maybe you should check the logs and see if you have any more info in the error message? Say maybe a "Permission denied" error message or something..?
jigsaw
Postby mgrant » Thu Jun 25, 2009 8:43 pm
jigsaw wrote:Did a quick test on my Linux, but it works fine for me. I tested with both a comma and an ampersand. Maybe you should check the logs and see if you have any more info in the error message? Say maybe a "Permission denied" error message or something..?
Looks like the problem is when the filesystem contains an HTML escaped ampersand (i.e. &)
So, in my example the actual path is:
/music/You\,\ Me\ \&amp\;\ Iowa/You\,\ Me\ \&amp\;\ Iowa
When displayed in the browser (or in the log) it automatically converts the "&" to just "&".
Apparently that's where subsonic chokes. Instead of trying to save the album art to:
is tries to save it to:
/music/You\,\ Me\ \&\ Iowa/You\,\ Me\ \&\ Iowa
which, of course, doesn't exist.
mgrant
Postby mgrant » Sat Aug 01, 2009 11:55 pm
bump...
Any thoughts on if this is an actual bug? And if so when/if it will get fixed? Now that I understand why it's failing I've just been "fixing" the paths. It seems that the software I use to manage the folder structure builds the paths from the ID3 tags and some of the ID3 tags contain the offending HTML (mostly "&" instead of the simpler "&".
-mg
mgrant
Postby sindre_mehus » Sun Aug 02, 2009 7:25 am
I've put it on my todo list, but can't promise when it will be fixed.
Thanks for reporting it ;-)
