Bug with "Next" on search Results ?
Postby sashimi » Tue Jun 30, 2009 2:46 pm
Upgraded to 3.7 yesterday. Noticed something and wondering if it is a bug.
When I do a search and the list is long I am shown first twenty five (1 to 25 of 45) results and a Next button. Clicking the Next Button does not seem to do anything. I do have Javascript enabled.
Any thoughts ?
thanks much.
d
sashimi
Postby CircularVirus » Thu Jul 02, 2009 2:40 pm
I have this same issue, but it only depends on what computer I am using. My computer at home I have no problem using the next button to scroll through results, but any computer at work can not use the next button.
CircularVirus
Postby sashimi » Thu Jul 02, 2009 2:54 pm
I will try it out tonight from another PC and on the Ubuntu machine (where Subsonic runs) directly and see what happens.
sashimi
Postby sindre_mehus » Thu Jul 02, 2009 6:37 pm
Sounds like a javascript problem. What browser are you using?
Postby sashimi » Thu Jul 02, 2009 8:09 pm
I am using IE 6. Most JS stuff seems to work ok. Should I check for something specific ?
sashimi
Postby sindre_mehus » Thu Jul 02, 2009 8:38 pm
I'm not sure. Is there any icon or message in the status bar indicating JS errors?
Otherwise, I strongly recommend upgrading to a more recent browser if you have the opportunity. IE6 is notoriously known for all its bugs and shortcomings.
Postby sashimi » Thu Jul 02, 2009 10:29 pm
No warning icon. But when I place my cursor on the Next button I see the status bar indicate a message "javascript:noop()"
Will try it on firefox.
thanks
sashimi
Postby donpearson » Fri Jul 03, 2009 5:14 pm
sashimi wrote:I am using IE 6. Most JS stuff seems to work ok. Should I check for something specific ?
move over to ff :wink:
Facebook Group:
donpearson
