Mixing two folders together
Postby eli2k » Sat Jul 18, 2009 9:21 am
I organized my music according to something like c:\music\genre, and d:\music\genre. I wanted Subsonic to sort of merge both folders from different drives, which it seems to do, but it adds folders from the second drive at the very bottom. If I click into a folder, say genreA, it will list folders from genreA from both drive C and D. But, if I click on the breadcrumb at the top (genreA), it will then only list folders on the folder genreA of that drive, and no the other drive.
Not sure if that is clear enough...
- Eli
eli2k
Postby 3R3 » Tue Jul 21, 2009 3:43 am
since you "click into a folder" you always select just one folder on one drive. therefore another folder on another drive has nothing to do with it, the way subsonic sees your music.
3R3
